citytrader 1 Posted September 8, 2023 Posted September 8, 2023 (edited) Hello, Emby installs fine but does not open in the browser, I tried v4.7.14 and v4.8.0 without success, could be possible that this versions are not compatible with QTS 5.1.1? I cleaned that cache without success too. Thanks! Edited September 8, 2023 by citytrader
citytrader 1 Posted September 8, 2023 Author Posted September 8, 2023 (edited) Hi! In the attachment the video so you can see all the process There is no firewall activated in QNS nor in the endpoint, Jellyfin works fine in this QNAP Embvy Issue.mp4 Edited September 8, 2023 by citytrader
Luke 42239 Posted September 9, 2023 Posted September 9, 2023 Try switching the port in the url from 8920 to 8096. The problem is QNAP wants to always open the browser using the https address, but you need to setup https in Emby Server before you can do that.
citytrader 1 Posted September 9, 2023 Author Posted September 9, 2023 Thanks a lot for your help and time, with port 8096 worked and now I found a final issue, when I try to watch a movie I get this error: No compatible streams are currently available. Please try again later or contact your system administrator for details. In Synology I can setup permissions, with QNAP I'm lost and another weird thing, there is no embyserver.txt under /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/logs I don´t know if Emby stores the data in another path...
Luke 42239 Posted September 9, 2023 Posted September 9, 2023 1 hour ago, citytrader said: Thanks a lot for your help and time, with port 8096 worked and now I found a final issue, when I try to watch a movie I get this error: No compatible streams are currently available. Please try again later or contact your system administrator for details. In Synology I can setup permissions, with QNAP I'm lost and another weird thing, there is no embyserver.txt under /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/logs I don´t know if Emby stores the data in another path... Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
citytrader 1 Posted September 10, 2023 Author Posted September 10, 2023 Thanks again for you help, there was a Guest permission to setup, different compared with Synology that once set as RD/WR it worked. 1
