Hairlock 1 Posted September 7, 2023 Posted September 7, 2023 Hello there, Currently using Emby on my synology 218play, I find it's a bit slow, so I started (for the first time) an ubuntu server with emby (on proxmox). I managed to install ubuntu and emby, but when adding the media folders (stored on my synology for now) it doesn't find anything. I press refresh media and nothing happens basically. I am not sure what protocol is used by emby, locally on my synology there is a user that is granted permissions. I have added NFS permissions for my server IP, but that doesn't seem to help. embyserver.txt
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 @Hairlocklooks like there's no access to your SMB share: 2023-09-07 19:52:14.902 Error App: Error getting files from smb://192.168.1.25 *** Error Report *** Version: 4.7.14.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.2.16-3-pve (tom@sbuild) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PVE 6.2.16-3 (20 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/lib/emby Application path: /opt/emby-server/system SharpCifs.Smb.SmbAuthException: SharpCifs.Smb.SmbAuthException: Logon failure: account currently disabled.
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 Here's my advice: Mount the SMB share to a local path in the OS and then import that local path into emby server instead If for some reason you can't do that, the 4.8 server has added the ability to enter smb credentials, in case those are necessary.
Hairlock 1 Posted September 7, 2023 Author Posted September 7, 2023 (edited) So it's like some sort of symbolic link ? Complete noob with Linux so i don't really know how to do those things. Can't i use nfs ? Edited September 7, 2023 by Hairlock
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 56 minutes ago, Hairlock said: So it's like some sort of symbolic link ? Complete noob with Linux so i don't really know how to do those things. Can't i use nfs ? I would follow this: https://support.zadarastorage.com/hc/en-us/articles/213024986-How-to-Mount-a-SMB-Share-in-Ubuntu
Hairlock 1 Posted September 8, 2023 Author Posted September 8, 2023 Gotcha, will try this then. That's until i move my storage away from the Synology to my proxmox install
Hairlock 1 Posted September 8, 2023 Author Posted September 8, 2023 Apparently you can't do that in proxmox if you use containers : https://bayton.org/docs/linux/lxd/mount-cifssmb-shares-rw-in-lxd-containers/ Will try the workaround though.
Solution Hairlock 1 Posted September 8, 2023 Author Solution Posted September 8, 2023 Found the solution, with some extra help found on the proxmox forums. https://forum.proxmox.com/threads/tutorial-unprivileged-lxcs-mount-cifs-shares.101795/
