nguyenf1 8 Posted September 7, 2023 Posted September 7, 2023 I think I found a workaround. I noticed that the the guide had the favorites filter enabled. Once I unselected favorites, the guide started working again.
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 @nguyenf1have you marked any channels as favorites?
nguyenf1 8 Posted September 7, 2023 Author Posted September 7, 2023 @LukeNo, i have not marked any channel favorites.
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 5 minutes ago, nguyenf1 said: @LukeNo, i have not marked any channel favorites. So it was actually working as expected, but you just forgot that the favorites filter was enabled, right?
nguyenf1 8 Posted September 7, 2023 Author Posted September 7, 2023 (edited) I didn't enable the filter myself, but I'm sure someone in the house could have enabled it. The first time launching the guide with favorites enabled works as expected, empty in my case. However, if I change to channel view and back to guide, the app will lockup and i think crash. Edited September 7, 2023 by nguyenf1
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 OK we'll take a look at it. @ebr Thanks for reporting.
