suming 21 Posted September 4, 2023 Posted September 4, 2023 1.When I updated the tvg logo address in the XML file and saved it again in the TV source, the logo displayed in the list did not update. Please fix this issue. 2.When some channels do not have automatic mapping and need to be manually mapped, a data source is selected in the list, but data channels are too difficult to select because there are too many channel lists to quickly find the channels you need, and some EPG providers provide channel lists in a disorderly order. The current selection method is a dropdown list box. It is recommended to change the selection method or add any matching (for example, I only need to enter one of the words, no matter where the word appears, all channels containing that word will be displayed in the dropdown list.)
suming 21 Posted September 4, 2023 Author Posted September 4, 2023 Additionally, there are several countries that are not sorted correctly
ebr 16338 Posted September 4, 2023 Posted September 4, 2023 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
