ZCXZXC 0 Posted September 4, 2023 Posted September 4, 2023 My Letv TV S50PRO uses emby tv 2.0.83 to play 4K HEVC. There is only sound but no picture. Sometimes the screen goes black and there is no sound. CPU: MStar 6A928. I want to ask is it because ffmpeg is very old? However, it can be played normally using Nova Video Player. The third-party NOVE VIDE player currently used plays it, but it is not native, which is very difficult for me to accept. Do I need to manually replace the ffmpeg decoder in emby tv?Can I know how to check what's wrong with it?
ebr 16337 Posted September 4, 2023 Posted September 4, 2023 Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
ZCXZXC 0 Posted September 12, 2023 Author Posted September 12, 2023 Sorry, something happened to delay me. I am only replying to you now. You should be able to use the log I saved while playing... hardware_detection-63830146030.txt ffmpeg-directstream-8ab7d8a2-31d7-4d28-91be-8bb5f1fed3e0_1.txt embyserver.txt
Luke 42245 Posted September 12, 2023 Posted September 12, 2023 5 hours ago, ZCXZXC said: Sorry, something happened to delay me. I am only replying to you now. You should be able to use the log I saved while playing... hardware_detection-63830146030.txt 135 kB · 0 downloads ffmpeg-directstream-8ab7d8a2-31d7-4d28-91be-8bb5f1fed3e0_1.txt 34.04 kB · 0 downloads embyserver.txt 178.21 kB · 0 downloads @ZCXZXC Hi, these are server logs. Thanks for sending these. We'd also like to see log files from the android app. There is a function in the app to send them. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
ZCXZXC 0 Posted September 13, 2023 Author Posted September 13, 2023 8 hours ago, Luke said: 8小时前,卢克说: @ZCXZXC Hi, these are server logs. Thanks for sending these. We'd also like to see log files from the android app. There is a function in the app to send them. 您好,这些是服务器日志。感谢您发送这些。我们还想查看 Android 应用程序的日志文件。应用程序中有一个功能可以发送它们。 Can you please play that item for a few seconds and then follow the instructions to send a log from the app? 您可以播放该项目几秒钟,然后按照说明从应用程序发送日志吗? The Android TV application emby has also been sent to you, but I don’t know if you can see that it is using the emby tv for 2.9.3 version. The log was sent successfully, but it did not tell me the corresponding receipt information, it just told me I succeeded.
Luke 42245 Posted September 14, 2023 Posted September 14, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
ZCXZXC 0 Posted September 15, 2023 Author Posted September 15, 2023 23 hours ago, Luke said: 23小时前,卢克说: Hi. Can you try sideloading our standard android app on the same device and see how that compares? 你好。您能否尝试在同一设备上侧载我们的标准 Android 应用程序并看看比较如何? https://emby.media/emby-for-android.html Thanks. 谢谢。 I downloaded the latest emby Android version, but it still cannot be played. There is sound but no picture. And I haven’t found where to send logs in the Android version. I searched for a long time and couldn’t find it. How can I send the emby Android version log to the background?
ZCXZXC 0 Posted September 15, 2023 Author Posted September 15, 2023 (edited) OK,After I played the content, I selected the menu log and sent it. My local user name is: zxc hardware_detection-63830146030.txt ffmpeg-directstream-8ab7d8a2-31d7-4d28-91be-8bb5f1fed3e0_1.txt embyserver.txt Edited September 15, 2023 by ZCXZXC
ZCXZXC 0 Posted September 15, 2023 Author Posted September 15, 2023 On 9/4/2023 at 10:00 PM, ebr said: Can you please play that item for a few seconds and then follow the instructions to send a log from the app? 您可以播放该项目几秒钟,然后按照说明从应用程序发送日志吗? OK,After I played the content, I selected the menu log and sent it. My local user name is: zxc
ebr 16337 Posted September 15, 2023 Posted September 15, 2023 HI. How was this video created? The video player cannot interpret the video stream at all and the device is complaining about unknown profile level of HEVC. If you use the "Playback Correction" option in the player, does it play?
ZCXZXC 0 Posted September 16, 2023 Author Posted September 16, 2023 (edited) 9 hours ago, ebr said: 9 小时前 ebr 说道: HI. How was this video created? The video player cannot interpret the video stream at all and the device is complaining about unknown profile level of HEVC. 你好。这个视频是如何制作的?视频播放器根本无法解释视频流,并且设备抱怨 HEVC 的配置文件级别未知。 If you use the "Playback Correction" option in the player, does it play? 如果您使用播放器中的“播放校正”选项,它会播放吗? I downloaded it from the PT website. I don’t know how it was made. The format is 4K HEVC. I have used “Playback Correction” and the picture is there, but where is the freeze frame? It takes a long time to change the picture. However, there is no problem at all when using Emby to connect the nova video player with a third-party player, and it can be played very smoothly. Is it possible that the FFPMEG version number is 5? Of course, nova video player is also open source and available on github. But its interface is really not too ugly, not as good-looking as emby. Can you tell the problem from the log? Is it because emby cannot recognize the encoding format? I guess it should be a general method of suppressing it. Edited September 16, 2023 by ZCXZXC
ZCXZXC 0 Posted September 16, 2023 Author Posted September 16, 2023 I cut off part of the information from other players, and I will upload the videos one by one to find out the reason. 三毛流浪记.S01E01.孤苦伶仃.11分钟.mkv
ZCXZXC 0 Posted September 19, 2023 Author Posted September 19, 2023 8 hours ago, Luke said: 8小时前,卢克说: This could be your issue: 这可能是你的问题: I turned off the server-side decoding. I just wanted the TV to decode without taking up server resources. Because nova vidoe palyer can play directly, I want to ask if my ffmpeg is too old and I need to upgrade ffmpeg, but I don’t know how to upgrade the ffmpeg format in emby Android TV.
Luke 42245 Posted September 19, 2023 Posted September 19, 2023 14 hours ago, ZCXZXC said: I turned off the server-side decoding. I just wanted the TV to decode without taking up server resources. Because nova vidoe palyer can play directly, I want to ask if my ffmpeg is too old and I need to upgrade ffmpeg, but I don’t know how to upgrade the ffmpeg format in emby Android TV. Hi, you don't need to turn those off. The server will already direct play whenever possible. Try turning them back on and then playing this content again and let us know how things compare. Thanks.
