jfarre20 3 Posted September 3, 2023 Posted September 3, 2023 My internet is really bad, but there's no other service so I'm stuck with it. I have a M3U I watch IPTV with, and it stutters/buffers etc. Its fine because I can still record or timeshift back in the buffer, but sometimes the stream just freezes (stuck on 1 frame, no audio) It will record this one frame with no audio for hours. If I force stop recording/end the stream, and go back in - its fine for a while again. Is there a way to have emby detect when the iptv connection freezes and have it disconnect/reconnect automatically until its going again? The only thing that stands out in the logs is the DUP number gets really high. This was frozen for over an hour before I noticed, it died around 14:10: 15:19:49.265 elapsed=02:19:51.22 frame=491804 fps= 59 q=31.0 size=N/A time=02:16:43.60 bitrate=N/A dup=9727 drop=233 throttle=off speed=0.978x 15:19:49.813 elapsed=02:19:51.77 frame=491841 fps= 59 q=31.0 size=N/A time=02:16:44.24 bitrate=N/A dup=9749 drop=233 throttle=off speed=0.978x 15:19:50.357 elapsed=02:19:52.32 frame=491871 fps= 59 q=31.0 size=N/A time=02:16:44.75 bitrate=N/A dup=9767 drop=233 throttle=off speed=0.978x 15:19:50.907 elapsed=02:19:52.87 frame=491891 fps= 59 q=31.0 size=N/A time=02:16:45.13 bitrate=N/A dup=9779 drop=233 throttle=off speed=0.978x 15:19:52.000 elapsed=02:19:53.96 frame=491911 fps= 59 q=31.0 size=N/A time=02:16:45.48 bitrate=N/A dup=9791 drop=233 throttle=off speed=0.978x
jfarre20 3 Posted September 3, 2023 Author Posted September 3, 2023 Oh here's my embyserver.log, its very large. I'm not 100% sure when it died, but someone told me at 14:10, and they said it was frozen before that for a while. embyserver.txt
Luke 42242 Posted September 3, 2023 Posted September 3, 2023 Hi, I think this may be improved in the upcoming 4.8 server release. 1
