Highcliffe14 2 Posted September 3, 2023 Posted September 3, 2023 Hi, I have Samsung Q9F freezing and jumping and pixellating. My system is Synology DS920 + hard-wired to the TV box. I do not have this problem with other endpoints - ipad (wifi) and computer monitor (wired) are working good. Hope you can help. Aspydistra embyserver-63829296000.txt ffmpeg-directstream-dc0f616d-7012-4b1a-b908-f6bd369f0a1a_1.txt ffmpeg-directstream-43d11b66-3d2c-4921-ae05-a681d56e2d8a_1 (1).txt ffmpeg-directstream-43d11b66-3d2c-4921-ae05-a681d56e2d8a_1.txt
SamES 1084 Posted September 3, 2023 Posted September 3, 2023 The ffmpeg logs are all from Chrome browser playbacks, not from the Q9F. Assuming that you are trying to play the same file on the TV (Hijack.2023.S01E01) your stuttering issues are due to there being too many subtitle tracks in the file. You will need to manually remove any that you don't need as more than about 20 embedded tracks causes stutttering issues on the TV
Highcliffe14 2 Posted September 4, 2023 Author Posted September 4, 2023 Thanks SamES - that did the trick. 1 1
