edanius 4 Posted September 2, 2023 Posted September 2, 2023 (edited) Hi, I have two emby servers one windows 10 pro (emby ver. 4.7.14) (have internet, this one write and download metadata). Other server one NAS synology DSM 7.2 (emby ver. 4.7.13) (no internet have no permission to write only read) , The both have the same source of data. Problem: The synology will not read the NFO ( I guess) file there. will be no info showing for the movie. The poster etc is showing. Edited September 2, 2023 by edanius
GrimReaper 4896 Posted September 2, 2023 Posted September 2, 2023 Do you have Metadata Readers>NFO enabled/ticked in your library settings?
edanius 4 Posted September 3, 2023 Author Posted September 3, 2023 18 hours ago, GrimReaper said: Do you have Metadata Readers>NFO enabled/ticked in your library settings? Yes I have
Solution GrimReaper 4896 Posted September 3, 2023 Solution Posted September 3, 2023 Try deleting that extra NFO file present and rescan. 2
edanius 4 Posted September 3, 2023 Author Posted September 3, 2023 51 minutes ago, GrimReaper said: Try deleting that extra NFO file present and rescan. Big Thx this worked, and the same issu in alot of other folder, At least I now know the problem. 1 1
