D1sk 4 Posted September 1, 2023 Posted September 1, 2023 Hello I don't know why but the backdrops only work for me with bibliothek Section "music videos", when I use the library series it doesn't work. the backdrops video is not played I have no idea why? I placed the exact same backdrops folder in a series folder to test.
Luke 42185 Posted September 1, 2023 Posted September 1, 2023 Hi, can you please provide an example? Thanks.
D1sk 4 Posted September 4, 2023 Author Posted September 4, 2023 On 9/1/2023 at 5:30 PM, Luke said: Hi, can you please provide an example? Thanks. I have once series and once music videos as bibliotheque category Here are two folders in that category I copied the exact same backdrops from the music video folder to the series folder I have once emby as stack in portainer and a second time as synolgy app Both have the same behavior. Version is the latest Emby Web 4.7.13.0 I have tested it via hppts to the outside via a proxy as well as internally via ip and port. every time the same behavior with music videos the backdrop is played with series not here is a video example where you can see this 230904112838.D1sk_AMV_–_Mozilla_Firefox.mp4 230904112905.Fansubs_–_Mozilla_Firefox.mp4 And here the user Setting
Luke 42185 Posted September 4, 2023 Posted September 4, 2023 Did you run a library scan after copying them in?
D1sk 4 Posted September 5, 2023 Author Posted September 5, 2023 9 hours ago, Luke said: Did you run a library scan after copying them in? Library scan on this folder or the entire library? I have not started this directly. However, I have added more data, there should but directly also start a scan? I will test this on occasion How is the behavior of a new scan are there again all actors in the nfo purely written? I have written a python script that iteratively goes through all orders and removes the acros from each nfo, because I do not want to have this information and the heads annoy me.
Luke 42185 Posted September 7, 2023 Posted September 7, 2023 On 9/5/2023 at 3:54 AM, D1sk said: Library scan on this folder or the entire library? Parent folder should be fine. The server has to become aware of the backdrop files before it can use them. That happens during the library scan. Please let us know if this helps. Thanks.
D1sk 4 Posted September 7, 2023 Author Posted September 7, 2023 1 hour ago, Luke said: Parent folder should be fine. The server has to become aware of the backdrop files before it can use them. That happens during the library scan. Please let us know if this helps. Thanks. Hello Luke it helps, thx for support 1
