Adminelite 4 Posted August 29, 2023 Posted August 29, 2023 I have created an rclone mount path on my NAS, and on the desktop, I can see everything and make changes. However, I am unable to access it on the Emby server. Emby also has read and write permissions on the folder.
Luke 42242 Posted August 29, 2023 Posted August 29, 2023 Hi, what happens when you try to access it? Are you sure you set the permissions on the right folder?
Adminelite 4 Posted September 2, 2023 Author Posted September 2, 2023 (edited) On 8/29/2023 at 11:13 PM, Luke said: Hi, what happens when you try to access it? Are you sure you set the permissions on the right folder? "I executed the command using a custom script on Synology: /volume1/@docker/btrfs/subvolumes/c411905668096c63e2e112439f70301308249f9ffb790ff92fa17b2778098abe/usr/bin/rclone mount NASWebDav:/ /volume1/discSSD/RS1221+" But when I check it in the terminal, only the root has access to it, not the Emby server. Even when I adjust the permissions, it doesn't allow me in the system. Edited September 2, 2023 by Adminelite
