Tikuf 663 Posted December 7, 2013 Posted December 7, 2013 I will have a hunt Cheeze. Its not something I have ever looked at or seen. Let me get back to you on that. 1
Cheesegeezer 3106 Posted December 7, 2013 Posted December 7, 2013 I will have a hunt Cheeze. Its not something I have ever looked at or seen. Let me get back to you on that. I'll save you the hassle @@Tikuf the hash needs to be calculated for each video stream(reliability may be an issue), so I guess it maybe a case of testing and see what happens and how accurate the subtitle sources are and what hash is generated by the calculation. mediainfo and ffprobe don't actually get the hash information for you.
Tikuf 663 Posted December 7, 2013 Posted December 7, 2013 Ya i was just about to post about the hash. It would also be very inaccurate if the movies had been reencoded at all. On a side note the fps wont matter unless they are graphical subs most sites offer text based srt, ass ssa . Im not saying the plugin couldn't be done. I would just be a major work to get it as a 100% solution.
Soultaker 225 Posted December 7, 2013 Posted December 7, 2013 I've written an application that allowed me to manually grab subtitles about a year ago. You'd select the file, and it will come back with a list of possible subs and then you choose the one that you think u need. At that time it was very hit and miss and I didnt persue it further. I can't imagine wanting to do the support for such an application as it's basically impossible. Such a shame because it would be really handy to have subtitles. 1
kreeturez 27 Posted December 7, 2013 Posted December 7, 2013 Yes, dynamic subtitle downloading is hit-or-miss. The way the XBMC guys do it (which actually works well in practice) is that their subtitle addon downloads the first 'sync' subtitle (which I believe is the first subtitle matching the video name with the same length as the video). If it gets it wrong (which does happen), hitting the Subtitle button a second time pops up a window with search results from the subtitle provider. Pick the next one on the list and you're normally sorted. The catch is that this pop-up window needs a front-end to achieve; so client-side support for the plugin would be required...
yardameus 221 Posted December 7, 2013 Author Posted December 7, 2013 I figured something like the MB2 subtitle plugin would suffice. To work well, it would also need a client side plugin. You search for a subtitle, it downloads the first one (like kreeturez was describing). If it's not right, you click the subtitle button in the menu again, it asks if you want to "blacklist" the one you got first, and downloads the next. Not very polished I guess, but worked a good percentage of the time for me. I agree that doing anything more than that would be a lot of work to develop and support, and wouldn't be worth the effort for the little bit of value added. 2
doron 10 Posted December 8, 2013 Posted December 8, 2013 I can tell you right now that will not work unless there is a timeshift and the only way that can happen is with human intervention which kind of defeats the purpose of an automated fetching system (sure it will get you a subtitle file) but without an external program to shift the subs in the actual file this will be a pita. Can you please explain why you feel that way? I must be missing something. If the subtitle file has been synced for this particular video file (which is what the filename-match and hash-match try to accomplish), and in case of streaming the server side is the one holding the subs file, why do you feel there'll be a need for timeshift? I figured something like the MB2 subtitle plugin would suffice. To work well, it would also need a client side plugin. You search for a subtitle, it downloads the first one (like kreeturez was describing). If it's not right, you click the subtitle button in the menu again, it asks if you want to "blacklist" the one you got first, and downloads the next. Not very polished I guess, but worked a good percentage of the time for me. I agree that doing anything more than that would be a lot of work to develop and support, and wouldn't be worth the effort for the little bit of value added. +1. That was my thought as well. It is not 100% and never will be; we should not seek 100% accuracy since (a) this is a hit-and-miss game and ( the st databases themselves are far from being 100% accurate - remember who feeds them. But the functionality of the MB2 plugin was "good enough" for most of us, and for me it was working well over 90% of the time, which is pretty good. You sound way more suited to the job than we are! Why dont you pick this up? You already have a lot of knowledge on the workings of the subtitles. I really wish I could allocate the time and resources to set up the environment, and do the coding and testing. As I said, I'd love to serve as alpha.
Cheesegeezer 3106 Posted December 8, 2013 Posted December 8, 2013 @@doron dont worry yourself, this is being discussed in the dev forum now. Thing is we want to cater for a complete solution and not a half arsed attempt, otherwise there comes about a hundred feature requests which should have been there in the first place! You know how it is 1
Pelon 203 Posted December 17, 2013 Posted December 17, 2013 Most of my MKV movies have subtitles files (external). I can enable them for all movies or disable them completely. I would also love the ability to switch subtitles on or off. If this has to be done at the MBS level, then I can create 2 users, one that has subtitles enabled, and one that doesn't, and just by switching profiles i can turn them on or off with the remote. Right now I rip the movies with the subtitles, but if I don't have the subtitles, then I use MCM to download the subtitles.
lancelot 0 Posted December 30, 2013 Posted December 30, 2013 +1 for subs, one of the 1st search terms i put on your seachbox, unfortunatelly hoped that this already was created...Hope someone can do it with a similar way as XBMC works
ebr 16339 Posted January 13, 2014 Posted January 13, 2014 Looks like Snazy has answered y'alls prayers...
Luke 42246 Posted January 14, 2014 Posted January 14, 2014 It has some issues, we're not sure yet. Hold off on downloading.
heula 192 Posted January 15, 2014 Posted January 15, 2014 notabenoid.com/ - for Russian subs http://www.addic7ed.com/ for multiple languages subtitles.
chopperno5 0 Posted January 17, 2014 Posted January 17, 2014 (edited) +1 for me. This is a massive requirement in our house - I currently have to download everything manually, but would love to see an automated server plug-in, although it would be preferable if it could monitor both movies and tv series as we tend to require subs for both! Multi language support too please (english and german). Edited January 17, 2014 by chopperno5
yardameus 221 Posted January 19, 2014 Author Posted January 19, 2014 Any word on Snazy's plugin? Major issue/revamp or just some more tweaking before release? Got me all excited.
Deihmos 170 Posted January 21, 2014 Posted January 21, 2014 i use couchpotato to organize my movie folders and it has an option to auto download the subs. It works well.
snake98 10 Posted January 21, 2014 Posted January 21, 2014 Looks like Snazy has answered y'alls prayers... Looks like someone killed that thread.
ttgapers 99 Posted January 30, 2014 Posted January 30, 2014 Any update on the plugin that was pulled? In MB2 there was a similar plugin that worked well. This is going to be very helpful. Although CP does it, it then requires an additional install again. No reason why MB3 shouldn't have the functionality natively via client(s) or plugin (preferred). Cheers. 1
KAOS 1 Posted April 20, 2014 Posted April 20, 2014 Just for clarification, this request thread is for a Subtitle Fetcher, right? I would be down for a new fetcher that works in MCT. :D 1
Luke 42246 Posted March 2, 2018 Posted March 2, 2018 The latest release of Emby Server (3.3), now features both OpenSubtitle downloading and SubDb subtitle downloading. Enjoy. 1
Luke 42246 Posted October 16, 2018 Posted October 16, 2018 We now have Podnapisi support: https://emby.media/community/index.php?/topic/64123-new-podnapisi-subtitle-plugin
Luke 42246 Posted February 22, 2019 Posted February 22, 2019 Addic7ed is now in the Emby plugin catalog. You'll need to configure your Addic7ed credentials in the plugin configuration. Enjoy. 1
nRafinia 79 Posted March 9, 2020 Posted March 9, 2020 I can't really speak to which is better than any others. There is also subscene.com. I've had the best luck with opensubtitle.org. I've only recently encountered subscene through the app Sublight. Handy, but hit or miss on some subtitles and some uploaders have accounts that you have to have an account for, so that would be a pain. Hi Subscene https://emby.media/community/index.php?/topic/83501-new-plugin-subscene-subtitle/ 1
