justinstreat 1 Posted August 27, 2023 Posted August 27, 2023 (edited) Hi Team, I am trying to play around with the CoverArt settings for the first time, however none of the images will load within the settings page. I can see the requests to load the images in devtools(chrome) and they are getting 401 replies. It looks like Emby is expecting the X-Emby-Token query parameter but its not being sent. I have tested both through my reverse proxy (traefik2.10) and direct to emby, same result both ways. CoverArt does seem to be doing its thing and adding the correct banners to images when viewing the library. I have tested this theory using the requested URL and appending "&X-Emby-Token=<<token>>" (token taken from the logs when i opened the settings page) to the url and the image loads with no issues. Details: Emby Server: Beta 4.8.0.43 OS: Docker on Ubuntu on WSL on Windows11 Image: emby/embyserver:beta Emby log entry related to this: Chrome DevTools console error: Please let me know if you need more info or if this should be in the beta forums instead of here (I haven't touched the CoverArt settings before so I dont know if this is a beta breakage or just my setup in general). EDIT: log attached. embyserver.txt Edited August 27, 2023 by justinstreat
roaku 842 Posted August 27, 2023 Posted August 27, 2023 It sounds like the plugin needs to be updated for compatibility with the change described here: 1
Solution Luke 42255 Posted August 27, 2023 Solution Posted August 27, 2023 Hi, yes we’ll be getting a plug-in update out for this. Thanks. 2
justinstreat 1 Posted August 27, 2023 Author Posted August 27, 2023 Love your work! Working perfectly now with that update, cheers! 1
