AtlasRedux 2 Posted August 25, 2023 Posted August 25, 2023 (edited) I've got a Samsung HW-Q960A soundbar setup. Side speaker audio is played on the rear speakers. This is extremely wrong. Windows plays them correctly. YouTube app on the TV plays them correctly. EVERYTHING else plays them correctly, except Emby, which plays side speaker output on rears. I used this to test Windows VS Emby: Downloads Page - Demolandia Edited August 25, 2023 by AtlasRedux
Luke 42234 Posted August 25, 2023 Posted August 25, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
AtlasRedux 2 Posted August 25, 2023 Author Posted August 25, 2023 (edited) 20 minutes ago, Luke said: What were you playing? I literally said that in the original post ... https://www.demolandia.net/downloads.html?id=919165883 Edited August 25, 2023 by AtlasRedux
Luke 42234 Posted August 25, 2023 Posted August 25, 2023 Please attach the ffmpeg log as well. Thanks.
AtlasRedux 2 Posted August 26, 2023 Author Posted August 26, 2023 hardware_detection-63828619288.txt ffmpeg-remux-5bf02c0e-fed8-4e57-a148-88e082b204d3_1.txt
Luke 42234 Posted August 26, 2023 Posted August 26, 2023 OK so you're playing the truehd track. As a test, if you select one of the ac3 tracks, how does that compare?
AtlasRedux 2 Posted August 26, 2023 Author Posted August 26, 2023 3 hours ago, Luke said: OK so you're playing the truehd track. As a test, if you select one of the ac3 tracks, how does that compare? Ah, the EAC 7.1 track plays it correctly.
AtlasRedux 2 Posted August 27, 2023 Author Posted August 27, 2023 6 hours ago, AtlasRedux said: Ah, the EAC 7.1 track plays it correctly. But it's not a track issue though, since the TrueHD 7.1 track plays correctly in Windows.
Luke 42234 Posted August 27, 2023 Posted August 27, 2023 6 hours ago, AtlasRedux said: Ah, the EAC 7.1 track plays it correctly. Curious, does it direct play, or remux through the server?
AtlasRedux 2 Posted August 27, 2023 Author Posted August 27, 2023 8 hours ago, Luke said: Curious, does it direct play, or remux through the server? TrueHD remuxes, EAC does not. There is no option to pick Direct for TrueHD.
rbjtech 5341 Posted August 28, 2023 Posted August 28, 2023 ffmpeg does not support 7.1 remuxing - thus it converts the 7.1 THD to 5.1 AC3/EAC3 - thus playing from your rears. The direct play 7.1 (EAC3) will use the sides - as would Emby if playing THD 7.1 (with no ffmpeg) via an AVR.
