speechles 2062 Posted August 24, 2023 Posted August 24, 2023 (edited) Imagine you are on the top row of the grid. You move all the way to the last tile on the right. You continue right past the edge of the screen. Shouldn't it then wrap to the first item on the left and move down the grid. Ie, it should move you to the 1st item of the 2nd row if you move right past the edge of the screen when you are on the last item of the 1st row. The samsung app version 1.4.8 is not respecting left/right from the extreme edges of the grid to navigate the grid up or down. It seems once you hit the left/right edge of any row of the grid if you press left or right again it just shoots you up to the Tabs at the top. In this case the "Movies" tab. No matter how deep you are in navigating down into the grid. If you forget and expect the grid to wrap right->left and left->right it just will not do that for some reason. On the Roku it does do this. You can freely wrap the grid and navigate any way you choose. It seems on the samsung app using the remote it isn't this easy. The main question is can the grid on the Samsung app please wrap right->left and left->right. Thanks. Edited August 24, 2023 by speechles
SamES 1084 Posted August 24, 2023 Posted August 24, 2023 I can't reproduce this with the current build on my TV - what year/model TV are you using?
speechles 2062 Posted September 14, 2023 Author Posted September 14, 2023 Oh snap just saw this. 75 inch samsung 8 series and 2021 model.
Solution Luke 42239 Posted September 14, 2023 Solution Posted September 14, 2023 Can you test the usb build and see how that compares?
speechles 2062 Posted September 14, 2023 Author Posted September 14, 2023 (edited) Sure. The store version must be behind. The USB version works. Edited September 19, 2023 by speechles 1
