vdrover 62 Posted August 23, 2023 Posted August 23, 2023 (edited) When modifying an Live TV channel lineup, it can be a bit cumbersome to update your electronic program guide or EPG. For example, if you are using an EPG editor, and you are hosting your own EPG files locally, the workflow might look like this: Update channels in EPG editor. Update the EPG files on your Emby server. Update your EPG in the Live TV or Scheduled Tasks area. If you have multiple EPGs, step 2 alone can be tedious. One way to simplify this process is to use a command line alias to merge multiple commands into one action. Before we start, let me jump a little bit ahead to show you how to create a command to run the scheduled EPG update task from the command line (step 3 above). Launch the scheduled EPG update task from the command line Visit the Emby backend and select `API` from the left menu. Create an API key and save it for later. Using the API key, list the IDs of all the scheduled tasks by entering the following command in your BROWSER: `http://your-emby-IP-address:8096/emby/ScheduledTasks?api_key=<your-API-Key>` Use your browsers search function to locate the following string: `RefreshGuide","Id":`. Note the task ID that immediately follows this string, such as `9492hsys60f7f17c9d0a4feb27`. Using the API key and the task ID, create a URL that will launch the 'Refresh Guide` task: `http://your-emby-IP-address:8096/emby/ScheduledTasks/Running/taskID?api_key=<your-API-Key>` Collect all your commands OK, now that we have the refresh guide command ready, here are some sample commands one might decide to combine into a single, easy-to remember alias: Download EPG 1 via command line: `wget -q https://your-epg.host/your-epg-data-1.xml -O $HOME/your-epg-data-1.xml` Download EPG 2 via command line: `wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml` Download EPG 3 via command line: `wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml` Update the EPG via command line instead of the emby backend: `curl -s -d GET http://your-emby-IP-address:8096/emby/ScheduledTasks/Running/taskID?api_key=<your-API-Key>` Combine commands You can use the logical AND operator `&&` to combine all 4 commands into one line: wget -q https://your-epg.host/your-epg-data-1.xml -O $HOME/your-epg-data-1.xml && wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml && https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml && curl -s -d GET http://your-emby-IP-address:8096/emby/ScheduledTasks/Running/taskID?api_key=<your-API-Key> Be sure to test that this works as expected from the CLI (remove the `-q` and `-s` flags to see the normal command output for example). Create alias Finally, create an alias using `nano ~/.bash_aliases` and enter the following: alias epg-updates='wget -q https://your-epg.host/your-epg-data-1.xml -O $HOME/your-epg-data-1.xml && wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml && https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml && curl -s -d GET http://your-emby-IP-address:8096/emby/ScheduledTasks/Running/taskID?api_key=<your-API-Key>' Once you've saved the file and exited nano, you need to run `source ~/.bash_aliases` for the new alias to be useable. Use the alias Simply type `epg-updates` from the CLI to update your local EPG files and the guide data in Emby. Automating If you prefer to automate this, simply use the commands above in a bash script, and schedule the script to run via crontask. I thought the process above might help folks who are not as familiar with using the developer tools in a browser as is often suggested in the Emby community. Edited August 23, 2023 by vdrover
Luke 42243 Posted August 24, 2023 Posted August 24, 2023 Hi, thanks for sharing. Stay tuned for improved editing features in future updates.
Ugnaughts 53 Posted December 1, 2023 Posted December 1, 2023 (edited) @vdrover @Luke On 8/23/2023 at 4:33 PM, vdrover said: Download EPG 1 via command line: `wget -q https://your-epg.host/your-epg-data-1.xml -O $HOME/your-epg-data-1.xml` Download EPG 2 via command line: `wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml` Download EPG 3 via command line: `wget -q https://your-epg.host/your-epg-data-2.xml -O $HOME/your-epg-data-2.xml` Update the EPG via command line instead of the emby backend: `curl -s -d GET http://your-emby-IP-address:8096/emby/ScheduledTasks/Running/taskID?api_key=<your-API-Key>` great work, unfortunately i'm still not able to get it to work. i just need refresh guide cmd, because im creating a script that deletes timers.json and exports a list of movies to re add. series timers is usually fine but needs guide refresh to populate timers.json from series.json. im using windows and dont need to download the 3 guides. just need to trigger refresh guide. was hoping the curl cmd would work. i can use the curl cmd for shutdown restart. it would be nice if they had a list of curl cmds for emby since emby don't have a built-in cmd line that i could find. Edited December 1, 2023 by joekingcool
Luke 42243 Posted December 2, 2023 Posted December 2, 2023 You could just use the api to run the refresh guide scheduled task.
Ugnaughts 53 Posted January 29, 2025 Posted January 29, 2025 On 12/1/2023 at 7:17 PM, Luke said: You could just use the api to run the refresh guide scheduled task. hello again, sorry i dint reply back to this. but im back on the quest again. this time for the companion app im making for emby. it seems from what reading that there is not a universal curl cmd for refreshing the guide if you have an ip key, correct? you have to look up the task id for that server for fresh guide and also have an api key, correct?
Luke 42243 Posted January 31, 2025 Posted January 31, 2025 On 1/28/2025 at 10:34 PM, joekingcool said: hello again, sorry i dint reply back to this. but im back on the quest again. this time for the companion app im making for emby. it seems from what reading that there is not a universal curl cmd for refreshing the guide if you have an ip key, correct? you have to look up the task id for that server for fresh guide and also have an api key, correct? Correct, although that's not a bad idea to add. 1
