Lyfesaver 135 Posted August 22, 2023 Posted August 22, 2023 Am I not finding the way to add Media Info and Subtitle overlays to Continued Watching so I can know which is 1080v4K, or is not an option atm? I understand if it is not doable at this time, just want to make sure I am not missing it Thanks!!
GrimReaper 4912 Posted August 22, 2023 Posted August 22, 2023 How did you setup Indicator Overlays (Media Info & Subtitle tabs) in your profile?
Lyfesaver 135 Posted August 23, 2023 Author Posted August 23, 2023 (edited) Not sure I understand the question. I have it set up to show in top right and bottom left, and it shows that way on cases. Edited August 23, 2023 by Lyfesaver
ebr 16346 Posted August 23, 2023 Posted August 23, 2023 Hi. Overlays are not added to thumbs and that's what is used in those rows.
GrimReaper 4912 Posted August 23, 2023 Posted August 23, 2023 (edited) 38 minutes ago, ebr said: Hi. Overlays are not added to thumbs and that's what is used in those rows. ?? They surely are for movies, but not for episodes (as explained here) in CW row, and that is a movie in the example above. Edited August 23, 2023 by GrimReaper
ebr 16346 Posted August 23, 2023 Posted August 23, 2023 Okay, sorry. The issue is the image being shown is the thumb for the series which doesn't have any media properties.
GrimReaper 4912 Posted August 23, 2023 Posted August 23, 2023 OP's example is a movie, and it should've been overlayed. https://www.themoviedb.org/movie/138-dracula
ebr 16346 Posted August 23, 2023 Posted August 23, 2023 I clearly need to go have another cup of coffee... but @Lyfesaveryou are sure the case for that exact same movie has overlays?
GrimReaper 4912 Posted August 23, 2023 Posted August 23, 2023 (edited) @Lyfesaver, try deleting cached images from your server programdata folder, cache\images\enhanced-images (delete all subfolders, images will be rebuilt); you can also clear browser cache. Edited August 23, 2023 by GrimReaper
ebr 16346 Posted August 23, 2023 Posted August 23, 2023 Or just refresh the item replacing all images. The case may have been created after the thumb...
Lyfesaver 135 Posted August 23, 2023 Author Posted August 23, 2023 I did all three of those things, no joy. I dont think I have ever seen the overlays on CW thumbs, btw
Lyfesaver 135 Posted August 26, 2023 Author Posted August 26, 2023 Is there anything I can do to help debug this?
ebr 16346 Posted August 26, 2023 Posted August 26, 2023 What treatment have you selected for your "Thumb" image time in CA? 1
Lyfesaver 135 Posted August 26, 2023 Author Posted August 26, 2023 It was set to Plain and when I changed it to Rounded it worked and then when I set it back to Plain it kept working
ebr 16346 Posted August 28, 2023 Posted August 28, 2023 Interesting... I just wanted to be sure it wasn't set to "Ignore".
