rbjtech 5344 Posted September 2, 2023 Posted September 2, 2023 (edited) @IsHome Hi - Thanks for the files. So I have recreated the issue and identified the issue. The file in question has EIA_608 closed captions (subtitles) in the Video stream - and that is stopping the AndroidTV client from working with the Dutch forced External SRT ( (and English Internal SRT as well actually). By removing the EIA_608 CC stream - it then works fine. So for a quick fix - you can run the files though ffmpeg to remove the CC stream - ffmpeg -i "input.mkv" -c copy -map 0 -bsf:v filter_units=remove_types=6 "output-noCC.mkv" However, the AndroidTV client really needs to be fixed to accept/or ignore the CC stream - as other players (VLC for example) work just fine - and display the CC stream as well if selected. I would suggest sending a link to the files to @ebr (as you did for me) and provide a link back to this thread for reference. I hope this helps .. Edited September 2, 2023 by rbjtech
IsHome 5 Posted September 2, 2023 Posted September 2, 2023 Hi rbjtech, Thanks for sorting out the problem I hadn't seen those CC streams in the mkv files, but because the subtitles work on the other Emby apps, I never thought to look for them. Those CC streams do indeed occur in the nfo files generated by Emby. And despite the fact that in the nfo the CC stream items 'default' and 'forced' are 'false', Emby Android TV seems to suffer from this. I will also send EBR the link to the files and the link back to this discussion. 1
Luke 42245 Posted September 2, 2023 Posted September 2, 2023 @IsHome Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
rbjtech 5344 Posted September 3, 2023 Posted September 3, 2023 On 01/09/2023 at 14:25, IsHome said: But this problem only occurs with Emby Android TV. Playing the same files/subtitles with Emby Android, Emby IOS or Emby MAC does NOT give you those problems. @Luke Please fix in the AndroidTV App... 1
IsHome 5 Posted September 3, 2023 Posted September 3, 2023 Hi @Luke Although it seems to me a pointless action (as mentioned earlier by me and rbjtech: with Emby Android no subtitle problems) as soon as I have a moment today or tomorrow I will execute your request and let you know the result.
Luke 42245 Posted September 3, 2023 Posted September 3, 2023 9 hours ago, IsHome said: Hi @Luke Although it seems to me a pointless action (as mentioned earlier by me and rbjtech: with Emby Android no subtitle problems) as soon as I have a moment today or tomorrow I will execute your request and let you know the result. That would be great, thanks !
rbjtech 5344 Posted September 4, 2023 Posted September 4, 2023 14 hours ago, Luke said: That would be great, thanks ! Really not sure sure why you are asking the OP to try this using the Android version @Luke- they have said it works fine already in their original post. Confirming it again is not going to change the AndroidTV App. The issue, as I've explained above - is the AndroidTV App does not like the CC stream - remove it, and it plays it fine. 1
IsHome 5 Posted September 4, 2023 Posted September 4, 2023 Hi @Luke, Here is my feedback regarding the installation of the Emby for Android app on my Android TV. Yesterday and today I tried to install the app on my Android TV alongside the Emby for Android TV app. That is despite installing file transfer apps, allowing sideloading of apps and accessing user data on the TV unfortunately failed to install the app. Even after finally copying the android Emby apk file on my android smartphone to the android TV, the installation of this gave an error But given the fact that the subtitles (as mentioned before) do work on my smartphone with Emby, I will stop this installation attempt.
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 On 9/4/2023 at 7:58 AM, IsHome said: Hi @Luke, Here is my feedback regarding the installation of the Emby for Android app on my Android TV. Yesterday and today I tried to install the app on my Android TV alongside the Emby for Android TV app. That is despite installing file transfer apps, allowing sideloading of apps and accessing user data on the TV unfortunately failed to install the app. Even after finally copying the android Emby apk file on my android smartphone to the android TV, the installation of this gave an error But given the fact that the subtitles (as mentioned before) do work on my smartphone with Emby, I will stop this installation attempt. OK we are working on getting it into the store and then you will be more easily able to install it onto your TV. Thanks.
IsHome 5 Posted September 8, 2023 Posted September 8, 2023 (edited) Hi @Luke Given your answer, I wonder the following: - If the standard app can be downloaded from the store, do I still need to install and test it on the Android TV? - or do you wait to fix the app until my test has been performed on the Android TV? - or do you follow rbjtech's request and fix the app asap? Edited September 8, 2023 by IsHome some word's missed
Luke 42245 Posted September 8, 2023 Posted September 8, 2023 7 minutes ago, IsHome said: Hi @Luke Given your answer, I wonder the following: - If the standard app can be downloaded from the store, do I still need to install and test it on the Android TV? - or do you wait to fix the app until my test has been performed on the Android TV? - or do you follow rbjtech's request and fix the app asap? The standard app is usually ahead in development, so that's why if you report an issue, it's helpful to know if it also occurs in the standard app. Right now it has to be sideloaded onto TV devices, but hopefully not too much longer.
Nabukodonosor 13 Posted September 9, 2023 Author Posted September 9, 2023 On 8/28/2023 at 8:05 PM, rbjtech said: As I've explained above, the serbian subs are not in sync with the audio - they are approx 4 seconds out. MPC must be doing the re-sync for you somehow in real time - emby is not, it is reading the file as is. So either re-sync the serbain srt's, use MPC or maybe another serbian srt source might have more synced subtitles. If you use the above attached srt file - emby will then work fine with that episode, as I have re-synced the file for you. You just need to do all the others ... So, to get to my problem. I found another subtitle, and they are in perfect sync in MPC on my PC, again. Also, I opened the subtitle in Notepad, and checked the times....they match what I hear in the video. What I mean, if someone says something in the video file at a specific time, that exact time is in the subtitle file. So the subtitle file and the video are in sync. And yet again, in the Emby it will only show the subtitle if I choose English, and it will be out of sync.
IsHome 5 Posted September 9, 2023 Posted September 9, 2023 4 hours ago, Nabukodonosor said: So, to get to my problem. I found another subtitle, and they are in perfect sync in MPC on my PC, again. Also, I opened the subtitle in Notepad, and checked the times....they match what I hear in the video. What I mean, if someone says something in the video file at a specific time, that exact time is in the subtitle file. So the subtitle file and the video are in sync. And yet again, in the Emby it will only show the subtitle if I choose English, and it will be out of sync. Your subtitle problem triggered me and I started looking. Ultimately, it turns out that a certain type of CC subtitle is present in certain series of files that causes the reported disruption. And yes, in that case too, only the English subtitle works at that moment. Fortunately, rbjtech managed to detect that and it only appears (as far as I know) in the Emby for Android TV app. To ensure this, this must be tested with the standard Emby for Android app (sideloading on the Android TV). Your device is Mi Stick 4k with AndroidTV and guess what the Mi Stick 4k runs on AndroidTV and therefore also Emby for Android TV
rbjtech 5344 Posted September 9, 2023 Posted September 9, 2023 @NabukodonosorYou issue is not related to this thread (which is related to a CC stream as @IsHomehas mentioned) - so please continue your subtitle issue in your original thread or it's going to get very confusing ! thanks.
Nabukodonosor 13 Posted September 9, 2023 Author Posted September 9, 2023 What do you mean my original thread?! This IS my original thread!
IsHome 5 Posted September 10, 2023 Posted September 10, 2023 Hi @Luke Today I spent some time sideloading the Emby for Android app, and it worked I was finally able to install this apk version (sideloading) on the Android TV. During testing, it turned out that, as expected, Emby for Android does show subtitles (*.nl.forced.srt) for mkv files that contain CC subtitles. Hopefully this information is now sufficient and that the Emby for Android TV app (as indicated/requested by rbjtech) will be adjusted in the short term.
ebr 16337 Posted September 10, 2023 Posted September 10, 2023 22 minutes ago, IsHome said: that contain CC subtitles Hi. I believe it is only a specific type of closed captions - the ones that Exo cannot or does not see.
IsHome 5 Posted September 10, 2023 Posted September 10, 2023 And what does that mean for the problem? That this problem cannot be solved in the Emby for Android TV version or...?
ebr 16337 Posted September 10, 2023 Posted September 10, 2023 2 minutes ago, IsHome said: And what does that mean for the problem? That this problem cannot be solved in the Emby for Android TV version or...? It just means the scope of the issue is very narrow. I understand it isn't for you, however. 1
Nabukodonosor 13 Posted September 10, 2023 Author Posted September 10, 2023 But why don't you just solve it? No matter how narrow it is. If you can, of course.
pwhodges 2033 Posted September 10, 2023 Posted September 10, 2023 Of course they'll solve it - but in turn. They're probably busy solving someone else's problem, or a problem that affects more people. Scheduling is inherently unfair... - frustrating, I know! Paul
rbjtech 5344 Posted September 10, 2023 Posted September 10, 2023 I've also provided a workaround by removing the CC with a simple ffmpeg filter. Not sure how many titles are effected, but until the fix, you could also go that route. 1
Nabukodonosor 13 Posted September 11, 2023 Author Posted September 11, 2023 That fix didn't work for me. The english subtitle was still there.
rbjtech 5344 Posted September 11, 2023 Posted September 11, 2023 5 hours ago, Nabukodonosor said: That fix didn't work for me. The english subtitle was still there. This fix is for the @IsHomeissues with encoded CC subtitles on AndroidTV. This is why you should never cross reference threads, as it all gets mixed up very quickly ...
ebr 16337 Posted September 11, 2023 Posted September 11, 2023 18 hours ago, Nabukodonosor said: But why don't you just solve it? No matter how narrow it is. If you can, of course Hi. For right now, the best solution is to use the standard app. https://emby.media/emby-for-android.html Thanks.
