Nickcarp 0 Posted August 21, 2023 Posted August 21, 2023 I am running emby on an openmediavault server. I have set up emby in portainer. I am unable to set up my movie library, all errors are the same "The path could nit be found. I am using the absolute path "/srv/dev-disk-by-uuid-409fd45a-64fe-4957-91a0-2bc1310a2727/Movies" but this doesn't work. I had emby working previously with no problems. Thanks in advance. Nick
Luke 42245 Posted August 21, 2023 Posted August 21, 2023 Hi there, are you sure Emby Server has permission to access the folder? Have you taken a look at this?
