INDICOHD 9 Posted August 20, 2023 Posted August 20, 2023 When I reproduce IPTV lists from Android in the Emby App, the streaming stops after a few seconds.When stops, it brings me to the Emby interface again.I've tried many Android devices (TV, Firetv Stick) and locally and remotely, but the problem is never solved
Luke 42237 Posted August 20, 2023 Posted August 20, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
INDICOHD 9 Posted August 20, 2023 Author Posted August 20, 2023 57 minutes ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! here you have embyserver.txt ffmpeg-directstream-467e2182-083f-4b0a-9601-3f7c7ad3f598_1.txt
Luke 42237 Posted August 26, 2023 Posted August 26, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Solution INDICOHD 9 Posted August 27, 2023 Author Solution Posted August 27, 2023 (edited) Hace 6 horas, Luke dijo: Hola. ¿Puedes intentar descargar nuestra aplicación estándar de Android en el mismo dispositivo y ver cómo se compara? https://emby.media/emby-para-android.html Gracias. El error se solucionó gracias a esto Edited August 27, 2023 by INDICOHD 1
