Arijeet 0 Posted August 20, 2023 Posted August 20, 2023 The conversion is just using CPU. hardware_detection-63828170551.txt
Abobader 3485 Posted August 20, 2023 Posted August 20, 2023 Hello Arijeet, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42185 Posted August 20, 2023 Posted August 20, 2023 Hi, please attach the Emby server and ffmpeg log from an example. Thanks.
Arijeet 0 Posted August 20, 2023 Author Posted August 20, 2023 embyserver.txtffmpeg-remux-4127f2a8-7bfc-47be-88b1-d17f0d6261a5_1.txt
Arijeet 0 Posted August 21, 2023 Author Posted August 21, 2023 I think I found the issue. Emby is using hardware acceleration but is using AMD's APU instead of Nvidia Card. The only solution I see, is to disable Radeon Graphics adapter. Let me know if you have any other way.
rbjtech 5335 Posted August 21, 2023 Posted August 21, 2023 (edited) 6 hours ago, Arijeet said: I think I found the issue. Emby is using hardware acceleration but is using AMD's APU instead of Nvidia Card. The only solution I see, is to disable Radeon Graphics adapter. Let me know if you have any other way. So a couple of Q's a) Do you have emby premier - as GPU acceleration is only active when you have premier, non premier must use CPU b) If you do have premier - what's listed in your server > transcoding > advanced page - there you can select/deselect and priortise multi GPU's. So ensure the RTX 3060 is put to the top and it should then be used by default. Edited August 21, 2023 by rbjtech
Luke 42185 Posted August 21, 2023 Posted August 21, 2023 On 8/20/2023 at 2:55 PM, Arijeet said: embyserver.txt 257.79 kB · 3 downloads ffmpeg-remux-4127f2a8-7bfc-47be-88b1-d17f0d6261a5_1.txt 142.95 kB · 2 downloads This example has no video transcoding, therefore use of the GPU is not necessary. Does this answer your question?
