Eisi2005 14 Posted August 17, 2023 Posted August 17, 2023 hi, i use emby as docker on an unraid system. So far everything is running fine. I have several libraries including one for 4k and one for BluRay. For some time now, whenever I add a movie to BluRay, it is not recognized. No cover is displayed and also no content. I have to manually identify the film by the title, then it is immediately found and everything is displayed. This does not happen with 4k movies. I have already compared both library settings. Does anyone have an idea there enclosed my log. embyserver2.txt
GrimReaper 4898 Posted August 17, 2023 Posted August 17, 2023 How are your BluRay files named and organized, as this can hardly be identified with such title: /mnt/Filme/S-U/movietitle - BluRay/movietitle - BluRay.mkv Quote 2023-08-17 16:56:27.999 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /bin/ffprobe -i file:"/mnt/Filme/S-U/movietitle - BluRay/movietitle - BluRay.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2023-08-17 16:56:28.046 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2023-08-17 16:56:28.052 Info App: MovieDbProvider: Finding id for item: movietitle - BluRay 2023-08-17 16:56:28.052 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=x_secret1_x&query=movietitle - BluRay&language=de 2023-08-17 16:56:28.352 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=x_secret1_x&query=movietitle BluRay&language=de 2023-08-17 16:56:28.652 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=x_secret1_x&query=movietitle - BluRay&language=en 2023-08-17 16:56:28.952 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=x_secret1_x&query=movietitle BluRay&language=en
Eisi2005 14 Posted August 21, 2023 Author Posted August 21, 2023 sorry for the late reply. my movies are always movietitle - BluRay or movietitle - UHD movietitle is just an example, the movie could also be called as an example. The Flash - BluRay/The Flash - BluRay.mkv The Flash - UHD/The Flash - UHD.mkv In the UHD library it finds all metadata and in the bluRay library it doesn't find it. My folder structure before is always /mnt/Movies/S-U/..... for BluRay or /mnt/4k/S-U/.... for 4k.
GrimReaper 4898 Posted August 21, 2023 Posted August 21, 2023 (edited) 18 minutes ago, Eisi2005 said: movietitle is just an example Not sure I'm following, above is a snippet from your log, provider is literally queried for a movie called "movietitle - Bluray" for German and English? 18 minutes ago, Eisi2005 said: The Flash - BluRay/The Flash - BluRay.mkv The Flash - UHD/The Flash - UHD.mkv Your movie folders should generally not be named as such, as that'll certainly make identification harder (or likely impossible in number of instances) since you have extra/unwanted terms in folder name with no year denoted. https://emby.media/support/articles/Movie-Naming.html Edited August 21, 2023 by GrimReaper
Eisi2005 14 Posted August 21, 2023 Author Posted August 21, 2023 I changed the title in the log afterwards because I didn't want this title to appear in the log here. It was a normal film title. I started using this folder structure years ago and had no problems with it until a few months ago. It's only been about 2-3 months that it hasn't found the data automatically, only when I search for the title manually does it work. Which title is more important for identification, the folder name or the file name.
GrimReaper 4898 Posted August 21, 2023 Posted August 21, 2023 1 minute ago, Eisi2005 said: Which title is more important for identification, the folder name or the file name. Folder name.
Eisi2005 14 Posted August 21, 2023 Author Posted August 21, 2023 OK, I'll test it in the folder name - leave out BluRay
Solution Eisi2005 14 Posted August 23, 2023 Author Solution Posted August 23, 2023 (edited) i have added 4 new movies and i leave out BluRay from folder name and all movies were immediately recognized very quickly and all movies are. Thanks for your help ! Edited August 23, 2023 by Eisi2005 1 1
