spaxx24 0 Posted August 17, 2023 Posted August 17, 2023 Has anyone actually got this to work properly? I'm using emby on my nvidia shield. My sound system is Arc + Sub + Era 300 Rears. When I play a movie with DTS sound and the included "PGSUB" subtitles the file cant play, its just buffering. If I either: Turn off DTS pass-through in Emby settings Turn off the PGSUB subtitles Turn off PGSUB subtitles and find manual subtitles on opensubtitles and use that SRT file instead It works. Problem is that I dont want to turn off pass-through and I would like to original subtitles. I understand that this happens because the transcoding gets to heavy, but is there any work around? The same file plays perfectly on Kodi with the PGSUB subtitles. I rather use emby than Kodi and since the same file works there I suppose there has to be a fix?
ebr 16307 Posted August 17, 2023 Posted August 17, 2023 Hi there, let's look at a specific example. Please attach the information requested in how to report a media playback issue. Thanks!
spaxx24 0 Posted August 17, 2023 Author Posted August 17, 2023 Sure, this is older but still the same problem.
Luke 42185 Posted August 17, 2023 Posted August 17, 2023 @spaxx24can we please look at a specific example using the version of Emby Server that you're running now?
spaxx24 0 Posted August 17, 2023 Author Posted August 17, 2023 (edited) 19 minutes ago, Luke said: @spaxx24can we please look at a specific example using the version of Emby Server that you're running now? Yes, I add them here. I try to play a movie with DTS sound and the PGSUB subtitles. It's just buffering and then I back out after 2 min or something ffmpeg-transcode-c98ddc5c-a818-4b11-89a2-c4aaf718e29c_1.txt ffmpeg-transcode-35a019de-de79-4b5e-808a-79561ba7ba62_1.txt ffmpeg-transcode-ecbdb2ea-32ca-456d-9432-fd6d57eb0e78_1.txt ffmpeg-transcode-6233fa3f-8296-4f57-bbb0-77e6c9dbfd73_1.txt ffmpeg-transcode-ed7e8901-8ae5-4d12-9be2-6f42c8d39c5d_1.txt embyserver.txt Edited August 17, 2023 by spaxx24
ebr 16307 Posted August 18, 2023 Posted August 18, 2023 Hi. How were these items created? It looks like there are multiple errors trying to direct play them and then ffmpeg isn't even getting going in most instances. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
spaxx24 0 Posted August 18, 2023 Author Posted August 18, 2023 I sent the logs right now, around 14.00 -5 UTC. What I did was I started Quantum Of Solace, with DTS sound passthrough on and subtitles OFF. It worked. Then I turned English subtitles on and it buffered for like 1 min maybe, played 5 seconds and then buffered again. I let it to this maybe 3 times and then I sent the logs. 3 hours ago, ebr said: Hi. How were these items created? It looks like there are multiple errors trying to direct play them and then ffmpeg isn't even getting going in most instances. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
ebr 16307 Posted August 18, 2023 Posted August 18, 2023 Hi. What was the name of the logged in user and the name of the server connected to? The one log I see around that time was for something without PGS subtitles (nor DTS audio).
spaxx24 0 Posted August 18, 2023 Author Posted August 18, 2023 34 minutes ago, ebr said: Hi. What was the name of the logged in user and the name of the server connected to? The one log I see around that time was for something without PGS subtitles (nor DTS audio). Admin, and the server is called "Intel NUC"
Luke 42185 Posted August 19, 2023 Posted August 19, 2023 On 8/17/2023 at 2:07 PM, spaxx24 said: Yes, I add them here. I try to play a movie with DTS sound and the PGSUB subtitles. It's just buffering and then I back out after 2 min or something ffmpeg-transcode-c98ddc5c-a818-4b11-89a2-c4aaf718e29c_1.txt 47.98 kB · 2 downloads ffmpeg-transcode-35a019de-de79-4b5e-808a-79561ba7ba62_1.txt 28.61 kB · 1 download ffmpeg-transcode-ecbdb2ea-32ca-456d-9432-fd6d57eb0e78_1.txt 48.04 kB · 0 downloads ffmpeg-transcode-6233fa3f-8296-4f57-bbb0-77e6c9dbfd73_1.txt 28.67 kB · 1 download ffmpeg-transcode-ed7e8901-8ae5-4d12-9be2-6f42c8d39c5d_1.txt 29.71 kB · 1 download embyserver.txt 1.39 MB · 0 downloads Hi, i believe these transcoding cases will be improved or resolved in the upcoming 4.8 server release. Thanks.
ebr 16307 Posted August 19, 2023 Posted August 19, 2023 18 hours ago, spaxx24 said: Admin, and the server is called "Intel NUC" Okay, so the item played in that log did not have PGS subs nor DTS audio. It was AC3 with closed captions (appears to have been a recording). In any case, it appears Luke is onto the solution. Thanks.
spaxx24 0 Posted August 19, 2023 Author Posted August 19, 2023 1 hour ago, ebr said: Okay, so the item played in that log did not have PGS subs nor DTS audio. It was AC3 with closed captions (appears to have been a recording). In any case, it appears Luke is onto the solution. Thanks. Then it wasnt the correct log 100% Okay guess i wait for 4.8
spaxx24 0 Posted August 19, 2023 Author Posted August 19, 2023 3 hours ago, ebr said: Okay, so the item played in that log did not have PGS subs nor DTS audio. It was AC3 with closed captions (appears to have been a recording). In any case, it appears Luke is onto the solution. Thanks. The latest beta seems to work a bit better, but still not good enough to work
Luke 42185 Posted August 26, 2023 Posted August 26, 2023 On 8/19/2023 at 1:37 PM, spaxx24 said: The latest beta seems to work a bit better, but still not good enough to work @spaxx24can you please provide a log example from 4.8.0.43? Thanks.
