danarm 9 Posted August 16, 2023 Posted August 16, 2023 (edited) Hello, 1. The date on the guide is still showing January, however when you go into the dropdown to choose the day you want the guide to show - the date shown is correct. 2. There seems to be additional text on the program description when using the 'information' option from viewing live tv screen. 3. From the live Tv home screen and selecting the recordings tab there is a 'messages.unknown' text on the sort tab and when you go to sort the recordings you get a 'There was an error processing the request etc message. tvOs: 16.6 (20M73) emby: 1.7.6 (1) Also wondering if we'll be able to see other info on the program guide in future app versions? e.g. parental rating, new or repeat programs and if a recording/ series has been scheduled etc. Edited August 16, 2023 by danarm added tags
SamES 1084 Posted August 16, 2023 Posted August 16, 2023 (edited) I can't reproduce the date issue in the guide, both are showing the right date for me. The &ndash issue has already been fixed for the next release. The next release also has a lot of changes to sorting, so I expect that the sort issues will already be fixed. I'll take another look at the guide/day issue, but please let me know if you see this is resolved in a release. Edited August 16, 2023 by SamES
danarm 9 Posted August 16, 2023 Author Posted August 16, 2023 Thanks SamES. See video, I've reproduced the date issue - seems to be related to sorting. Date changes when you press on the guide button after attempting to sort. Untitled video.mp4 1
SamES 1084 Posted August 16, 2023 Posted August 16, 2023 OK, that is probably just a consequence of the broken sort messing with the guide. Let me work on the sort option and make sure it's resolved in the recent changes
SamES 1084 Posted August 17, 2023 Posted August 17, 2023 14 hours ago, SamES said: Let me work on the sort option and make sure it's resolved in the recent changes Should be fixed for the next update, please let me know how it goes 1
danarm 9 Posted August 18, 2023 Author Posted August 18, 2023 Sorting is all good now but the guide date issue remains. Selecting live tv, then guide and then go to any listed tv program it will change from current month to January. 1
SamES 1084 Posted August 18, 2023 Posted August 18, 2023 1 hour ago, danarm said: Selecting live tv, then guide and then go to any listed tv program it will change from current month to January. Great, that helped. I can reproduce it now. Thanks!
Solution SamES 1084 Posted August 23, 2023 Solution Posted August 23, 2023 On 18/08/2023 at 22:37, danarm said: Sorting is all good now but the guide date issue remains. Selecting live tv, then guide and then go to any listed tv program it will change from current month to January. Should be fixed for the next release 1
