Przemek 70 Posted September 2, 2023 Author Posted September 2, 2023 On 8/31/2023 at 4:23 AM, Luke said: What do you mean by because deluge? I read that if I don't set in deluge to download incomplete to some folder it will download it to docker.img.
Przemek 70 Posted September 2, 2023 Author Posted September 2, 2023 Hello @jaycedkYou said that You use ssd connected with usb in unraid as storage for Emby transcoding?
Przemek 70 Posted September 2, 2023 Author Posted September 2, 2023 23 minutes ago, jaycedk said: No not usb, that will slow it down. I buy nvme m.2 Samsung Evo 970 and connect it with ugreen USB 3.2 case. It's better to use transcoding folder on array SATA drive?
Neminem 1623 Posted September 3, 2023 Posted September 3, 2023 Yes in that case, that will be faster. You should ask, people over at unraid, they don't bite.
Przemek 70 Posted September 3, 2023 Author Posted September 3, 2023 2 hours ago, jaycedk said: Yes in that case, that will be faster. You should ask, people over at unraid, they don't bite. Yes, thanks.
Przemek 70 Posted September 4, 2023 Author Posted September 4, 2023 On 9/3/2023 at 8:09 AM, Luke said: Let us know what you find. Hi, I don't know how that could be related but today I noticed Emby don't show movie I download. Movie is in folder where I usually download. There's no problem in Radarr. I scan Library and refresh it. I search for that movie also. It add to movies folder about 50m ago. Regards. embyserver.txt
Przemek 70 Posted September 4, 2023 Author Posted September 4, 2023 (edited) I see now one user on Emby watch directly and second is transcoding. I attach screen how it looks on unRAID: It means VAAPi don't work? Edited September 4, 2023 by Przemek
Neminem 1623 Posted September 5, 2023 Posted September 5, 2023 You need to provide log files from when this is happening. Other wise Dev's can't help you.
Luke 42245 Posted September 7, 2023 Posted September 7, 2023 On 9/5/2023 at 12:34 AM, jaycedk said: You need to provide log files from when this is happening. Other wise Dev's can't help you. @Przemek?
Przemek 70 Posted September 7, 2023 Author Posted September 7, 2023 Sorry @Lukeand @jaycedkI see that was DupeGuru finding duplicate files. I forget it was working at this time. Regards. 1
Przemek 70 Posted October 15, 2023 Author Posted October 15, 2023 (edited) Hello again. Today I mount new Nvidia RTX3060 to my server. I want to try steam-headless on it. When I turned on emby won't work. I install nvidia plugin and reboot. Then Emby start working but don't show any devices for transcoding. hardware_detection-63832953309.txt embyserver.txt Edited October 15, 2023 by Przemek
Neminem 1623 Posted October 15, 2023 Posted October 15, 2023 @Przemek why are you going away from iGPU ? It has no limitations like Nvidia max 2 transcodes if driver is not hacked. But try this.
Przemek 70 Posted October 15, 2023 Author Posted October 15, 2023 6 minutes ago, jaycedk said: @Przemek why are you going away from iGPU ? It has no limitations like Nvidia max 2 transcodes if driver is not hacked. But try this. I don't go away from iGPU. I want to use nvidia for steam-headless.
Neminem 1623 Posted October 15, 2023 Posted October 15, 2023 I don't go away from iGPU. I want to use nvidia for steam-headless ? Then I don't know what you want to do, and why.
Przemek 70 Posted October 15, 2023 Author Posted October 15, 2023 Just now, jaycedk said: I don't go away from iGPU. I want to use nvidia for steam-headless ? Then I don't know what you want to do, and why. As I mentioned in first post today I want to try my new Nvidia card with steam-headless to play games. I have connected Nvidia card to tv with hdmi-displayport. Unfortunately my Emby don't see VAAPI anymore. I try to reinstall, I turn off VM. I reboot but nothing helps. I'm on the beginning with this situation like on first post of that thread.
Neminem 1623 Posted October 15, 2023 Posted October 15, 2023 Ok never tried that, As I said last time you played around with VM's and Docker. You can only use that GPU with one or the other. Not both. I think you need to ask over at Unraid forum since you clearly did something to break GPU in emby docker. By playing around with VM's.
Przemek 70 Posted October 15, 2023 Author Posted October 15, 2023 19 minutes ago, jaycedk said: Ok never tried that, As I said last time you played around with VM's and Docker. You can only use that GPU with one or the other. Not both. I think you need to ask over at Unraid forum since you clearly did something to break GPU in emby docker. By playing around with VM's. I disable VM on unRAID. I want to use Intel GPU (VAAPi) on Emby and Nvidia in docker steam-headless.
Neminem 1623 Posted October 15, 2023 Posted October 15, 2023 Yes ask over at Unraid forum how to do that. That you OS and has nothing to do with Emby.
Przemek 70 Posted October 18, 2023 Author Posted October 18, 2023 I find solution to make changes in bios settings. Now works great. VAAPi for Emby and nvidia for steam Regards. 1
