cptlores 41 Posted August 15, 2023 Posted August 15, 2023 https://github.com/advisories/GHSA-7j8v-mxgr-f46m
Luke 42185 Posted August 15, 2023 Posted August 15, 2023 HI, that's already patched in the beta. I think we'll be doing a 4.7.14 release so we can get that fix included as well. This is only high in severity if you actually click on a link that takes you to your server and contains javascript in the url. That means someone has to send you that link first, and then you have to decide to click on it. Since you are the master of your own server, you're most likely not going to need someone to send you a link in order to be able to reach it. 1
TeamB 2440 Posted August 16, 2023 Posted August 16, 2023 (edited) It is for links in forums with links to local servers i.e. localhost, if you click on it on the machine running emby it will probably work. Edited August 16, 2023 by TeamB
TMCsw 256 Posted August 26, 2023 Posted August 26, 2023 On 8/15/2023 at 4:28 PM, Luke said: HI, that's already patched in the beta. I think we'll be doing a 4.7.14 release so we can get that fix included as well. Not a big deal for me but is this included? There is no mention of this! I just wish @Lukewould give better descriptions about what the releases includes (or a link for more details) Thanks.
