BillOatman 597 Posted August 9, 2023 Posted August 9, 2023 In Live TV select Edit in the XMLTV ellipsis ... And you see ...
BillOatman 597 Posted August 10, 2023 Author Posted August 10, 2023 (edited) 18 hours ago, Luke said: Hi, what version of the Emby Windows app? Not reproducible apparently, sorry for the time waster. Edited August 10, 2023 by BillOatman
Solution Luke 42237 Posted August 10, 2023 Solution Posted August 10, 2023 Actually this will still be an issue in the windows store version. 1
mitch2471 11 Posted August 14, 2023 Posted August 14, 2023 I'm getting the same thing shown in billoatmans screenshots when I enter the video settings. Ive noticed that 4k video playback is now stuttering so went to the settings section, clicked on video & got the same thing shown above. Options overlap over the main settings options making it impossible to change any video settings. It would be nice to go maybe a few months without an emby update breaking a basic feature! Luke are you aware of this problem? Is it being worked on? P.s. would it be possible for you to post a link for a stable server & stable theater download that you're customers can download & use if they run into problems or are just fed up with things being broken by updates.
Luke 42237 Posted August 14, 2023 Posted August 14, 2023 9 minutes ago, mitch2471 said: I'm getting the same thing shown in billoatmans screenshots when I enter the video settings. Ive noticed that 4k video playback is now stuttering so went to the settings section, clicked on video & got the same thing shown above. Options overlap over the main settings options making it impossible to change any video settings. It would be nice to go maybe a few months without an emby update breaking a basic feature! Luke are you aware of this problem? Is it being worked on? P.s. would it be possible for you to post a link for a stable server & stable theater download that you're customers can download & use if they run into problems or are just fed up with things being broken by updates. HI, what settings screen are you seeing this on? It's only an issue on very specific ones, like the live tv settngs and plugin settings.
mitch2471 11 Posted August 14, 2023 Posted August 14, 2023 9 minutes ago, Luke said: HI, what settings screen are you seeing this on? It's only an issue on very specific ones, like the live tv settngs and plugin settings. In app settings, video under the emby theater heading.
Luke 42237 Posted August 15, 2023 Posted August 15, 2023 4 hours ago, mitch2471 said: In app settings, video under the emby theater heading. What version of Emby Theater are you running? The video settings seem to be working just fine in my testing.
mitch2471 11 Posted August 15, 2023 Posted August 15, 2023 8 hours ago, Luke said: What version of Emby Theater are you running? The video settings seem to be working just fine in my testing. It happens in app settings when you choose either CEC, Audio or Video. Version is 3.0.20. Can I just have a link to a previous stable windows release of Theater? I don't need all the latest features, just something that can handle direct play of up to 4k video & live tv. Whichever previous version was capable of this will do. I don't have the time in my life anymore to frequent the forums looking for answers to fix things that literally 24hrs ago did not need fixing or in worst cases like this when I have to actually make a post & bring it to your attention. When we switch the tv/emby on in the evening its to relax, not fault find.
Luke 42237 Posted August 15, 2023 Posted August 15, 2023 11 hours ago, mitch2471 said: It happens in app settings when you choose either CEC, Audio or Video. Version is 3.0.20. Can I just have a link to a previous stable windows release of Theater? I don't need all the latest features, just something that can handle direct play of up to 4k video & live tv. Whichever previous version was capable of this will do. I don't have the time in my life anymore to frequent the forums looking for answers to fix things that literally 24hrs ago did not need fixing or in worst cases like this when I have to actually make a post & bring it to your attention. When we switch the tv/emby on in the evening its to relax, not fault find. Strange. Can you try restarting the app and see if it's still an issue?
mitch2471 11 Posted August 15, 2023 Posted August 15, 2023 Restarted. Still persists. It's been happening since the weekend. I wasn't overly bothered until I realised that 4k films were stuttering. I went in to the menu to check the video settings & realised that I am now unable to make any changes because of this issue.
Luke 42237 Posted August 16, 2023 Posted August 16, 2023 Ok, please give it a try again tomorrow and let us know if the issue is resolved. Thanks.
mitch2471 11 Posted August 16, 2023 Posted August 16, 2023 No change. Luke is this a problem with the theater app or the server? Can you post a link to a previous version of the theater app or server that I can use in the meantime?
Luke 42237 Posted August 18, 2023 Posted August 18, 2023 Hi, can you try it again? Are you running a VPN by chance?
mitch2471 11 Posted August 18, 2023 Posted August 18, 2023 3 hours ago, Luke said: Hi, can you try it again? Are you running a VPN by chance? Just tried it now. No change. No I am not using a vpn. When was the last server & theater app update last pushed out?
mitch2471 11 Posted August 20, 2023 Posted August 20, 2023 Luke I hate to keep asking but it seems like you can't recreate the problem I'm experiencing. As such you can't remedy it. Can you pls just post a link to a previous stable server/theater I can install.
Luke 42237 Posted August 23, 2023 Posted August 23, 2023 As a last resort have you tried uninstalling theater and then reinstalling?
