DragonSkills99 4 Posted August 8, 2023 Posted August 8, 2023 Hey, when the subtitles are in DVDSUB format, the android app will simply not display it. The windows app on the other hand can play it just fine and even using the browser something is displayed (but in that case it's not really usable as it's too big and gets out of the screen) I've attached a screenshot so you know, which format the subtitle is exactly in. Sadly I really cannot send you said file as it's just a private copy of a disc I own and share it would be illegal. Also the "intelligent" subtitle mode doesn't work, the way it describes itself. The subtitles are just disabled no matter if the audio is german an there is a forced subtitle available or the audio is japanese and there are german subs available. Greetings DragonSkills99
Solution Luke 42243 Posted August 9, 2023 Solution Posted August 9, 2023 Hi, this should be resolved in the next update to Emby for Android. Thanks.
DragonSkills99 4 Posted August 9, 2023 Author Posted August 9, 2023 2 hours ago, Luke said: Hi, this should be resolved in the next update to Emby for Android. Thanks. Great, thanks.
