GBREEZY_83 8 Posted August 7, 2023 Posted August 7, 2023 Hi quick question how do you offset the EPG on Emby? Two of my channels are off lol
Luke 42243 Posted August 17, 2023 Posted August 17, 2023 HI, what tuner and guide source are you using?
GBREEZY_83 8 Posted August 18, 2023 Author Posted August 18, 2023 Hi, I'm using HDHR and Emby guide, but for my M3U. I figured it out. Thanks for reaching out.
Luke 42243 Posted August 18, 2023 Posted August 18, 2023 2 hours ago, GBREEZY_83 said: Hi, I'm using HDHR and Emby guide, but for my M3U. I figured it out. Thanks for reaching out. What was the solution?
Solution GBREEZY_83 8 Posted August 26, 2023 Author Solution Posted August 26, 2023 Just had to offset my M3U playlist on the EPG guide I subscribe to lol 1
