seanbuff 1356 Posted August 24, 2023 Posted August 24, 2023 3 minutes ago, rbjtech said: I've tested both issues but to be fair, I never had the 'forced to stay in the letter chosen' issue to start with, only the jump to Z issue. Thanks. Well I'm the opposite of you, I've never experienced the 'jumps to Z issue' only the other one 1
seanbuff 1356 Posted August 24, 2023 Posted August 24, 2023 50 minutes ago, Ronstang said: I will report if I am in error but I could not get it to reproduce either in a several minutes of scrolling and changing letters so it seems OK now. I feel like there has been some sort of improvement, as I can typically get through at least 3 letter groups now. It used to always be just 1 letter section. So now if I start at 'E' ...I can now almost make it to 'H', or if I start at 'I' i can almost make it to 'L' ...never any more than 3 letter groups though. 'X' is always the same though, and will only ever make it 2-clicks to almost 'Y' -- without fail. See how you go with longer testing when you can. Thx
rbjtech 5344 Posted August 24, 2023 Posted August 24, 2023 I'm wondering if it related to the number of items perhaps - I have ~1800 Movies and ~800 Shows But I can select 'B' and scroll (in items) all the way to Z without issues - so unless you have more than 1800 items in the 3 letter groups - then I doubt it's that.. Odd.
seanbuff 1356 Posted August 24, 2023 Posted August 24, 2023 7 minutes ago, rbjtech said: I'm wondering if it related to the number of items perhaps - I have ~1800 Movies and ~800 Shows Yes I was just about to come back and report on that. So after a little more testing, I limited this test user to a smaller portion of that same library, which gives roughly half the amount of items in the total view ~2500 items Magically the issue disappears. So as @ebrsuspected previously, it does have something to do with larger lists. 1
Ronstang 294 Posted August 24, 2023 Author Posted August 24, 2023 5 hours ago, rbjtech said: I can't re-produce this - everything is working ok now. What Server version are you using ? I'm using Beta Server v4.8.0.42 and AndroidTV Client v2.0.90 Same here, once I installed AndroidTV Client v2.0.90 all the issues described in this thread went away for me and I tested it over and over by switching to a different letter and scrolling endlessly until I was three letters later and I was never able to do this before without it jumping back to the beginning. It also never jumped to "Z" even once....so it appears as this issue is fixed.
Ronstang 294 Posted August 24, 2023 Author Posted August 24, 2023 5 hours ago, seanbuff said: Yes I was just about to come back and report on that. So after a little more testing, I limited this test user to a smaller portion of that same library, which gives roughly half the amount of items in the total view ~2500 items Magically the issue disappears. So as @ebrsuspected previously, it does have something to do with larger lists. I can no longer reproduce this issue and the list I was checking was a directory with 4300+ movies in it.
ebr 16337 Posted August 24, 2023 Posted August 24, 2023 5 hours ago, seanbuff said: So now if I start at 'E' ...I can now almost make it to 'H', or if I start at 'I' i can almost make it to 'L' ...never any more than 3 letter groups though. Can you reproduce this just until that unwanted focus change and then immediately back out and send the log from the app?
seanbuff 1356 Posted August 24, 2023 Posted August 24, 2023 6 minutes ago, ebr said: Can you reproduce this just until that unwanted focus change and then immediately back out and send the log from the app? Done. Started at E and made it to just before H Time: 1:05pm UTC User: TestyMcTest
ebr 16337 Posted August 24, 2023 Posted August 24, 2023 Thanks. It looks like you are pressing the letter button again after the system retrieves more items to fill in the cache. I know you actually aren't but the program is responding as if you had. Try this - do a letter jump and then scroll down a few items. Then move back over to the letter list and move to a different character - any character - BUT DON'T CLICK IT. Just move back to the list and now continue scrolling down until it does the unwanted jump. Which start letter did you end up on? The one you selected at first or the one where the cursor was when you moved on the list later?
seanbuff 1356 Posted August 24, 2023 Posted August 24, 2023 7 minutes ago, ebr said: Which start letter did you end up on? The one you selected at first or the one where the cursor was when you moved on the list later? Okay tried that scenario twice. First started at E ... scrolled a few rows, then went and hovered over R and went back to scrolling the list -- the jump brought me back to the top of my original letter of E Tried it again starting with Q scrolled a few, hovered over D (didn't click) kept scrolling till it jumped me back to top of Q
ebr 16337 Posted August 24, 2023 Posted August 24, 2023 Thanks for that. I'm afraid I have no idea how that is happening...
