Xor_van_Dorf 2 Posted August 5, 2023 Posted August 5, 2023 (edited) Hi, Emby server is installed in a jail on Truenas Core. Everything was working fine until I did a pkg upgrade... It upgraded a bunch of pkgs and now, the web interface is just showing "Emby". I've tried to install the 4.8 beta, but it does the same thing. I've attached the most recent log and the packages that were upgraded. Surely, a package needs to be downgraded? I tried to downgrade ffmpeg, but no Thanks! embyserver-63826787875.txt Edited August 5, 2023 by Xor_van_Dorf
Xor_van_Dorf 2 Posted August 5, 2023 Author Posted August 5, 2023 It was still working on my phone and Shield tv, but it's now not working anymore. I will try to reinstall.
Solution Xor_van_Dorf 2 Posted August 5, 2023 Author Solution Posted August 5, 2023 Did some rollback and I found the culprit > jpeg-turbo 3.0. I downgraded to 2.1.5.1 and voila! 1
nikx123 1 Posted August 6, 2023 Posted August 6, 2023 Thank you, had similar problem that web interface not loading correctly. Did a rollback on the jail, and waiting for a emby upgrade before upgrading the jail again. 1
