sshapery 6 Posted August 3, 2023 Posted August 3, 2023 I've run into a situation where all my movies are populating fine, but the TV shows are showing either extracted embedded shots or a black square. If I go into each show individually, click Edit images it shows a gray box in the Primary until I click search, and then manually download one. Any ideas on how to automate this?
Abobader 3485 Posted August 3, 2023 Posted August 3, 2023 Hello sshapery, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GrimReaper 4845 Posted August 3, 2023 Posted August 3, 2023 What are your TV shows library enabled Image fetchers and in what order?
Solution GrimReaper 4845 Posted August 3, 2023 Solution Posted August 3, 2023 Move OMDB to the bottom of preferred Series Image Fetchers and Refresh Metadata with Replace images selected.
sshapery 6 Posted August 3, 2023 Author Posted August 3, 2023 That seems to have done it, thank you so much! 1 1
