MorTuadh 1 Posted August 3, 2023 Posted August 3, 2023 Hi, I'm not sure if this is an Emby issue or a Synology issue. I'm using Emby 4.7.13.0 on Synology DS416j with DSM 7.1.1-42962 Update 5. I have library folders on my NAS but I would like to scan some shared folders on my PC too because I ran out of space on my NAS. I would like to scan movies into my library with featurettes. I followed the naming guidelines. For example: a folder named "WarGames (1983)" with the movie file and a subfolder named "Featurettes" with the movie extra files. If I move this folder into my Movie folder on the NAS, everything's fine, Emby recognizes my files correctly. If I move this folder into my network shared folder on my PC, Emby thinks the movie extras are separate movies and doesn't associates them with the movie. NFO files are created in the folder but with zero byte size. The folder is shared in my network for everybody with read and write permissions. Could you please help me? Thank you.
Luke 42242 Posted August 3, 2023 Posted August 3, 2023 Hi there, can you show us the exact folder structure? Thanks.
MorTuadh 1 Posted August 3, 2023 Author Posted August 3, 2023 (edited) 45 minutes ago, Luke said: Hi there, can you show us the exact folder structure? Thanks. Of course. This is the network shared folder on my PC with some test files. Emby creates zero byte NFO files here. If I move these folders to my movie folder on the NAS, there's no issue. Directory of e:\movies 2023. 08. 03. 19:20 <DIR> . 2023. 08. 03. 19:40 <DIR> Aeon Flux (2005) 2023. 08. 03. 19:40 <DIR> WarGames (1983) 0 File(s) 0 bytes Directory of e:\movies\Aeon Flux (2005) 2023. 08. 03. 19:40 <DIR> . 2023. 08. 03. 19:20 <DIR> .. 2023. 08. 02. 20:44 51˙991 Aeon.Flux.2005.OPEN.MATTE.1080p.AMZN.WEB-DL.DDP5.1.H.264-None.eng.srt 2023. 08. 02. 20:44 53˙540 Aeon.Flux.2005.OPEN.MATTE.1080p.AMZN.WEB-DL.DDP5.1.H.264-None.hun_DVD.srt 2023. 08. 02. 20:46 53˙476 Aeon.Flux.2005.OPEN.MATTE.1080p.AMZN.WEB-DL.DDP5.1.H.264-None.hun_NF.srt 2022. 12. 03. 13:34 6˙660˙932˙236 Aeon.Flux.2005.OPEN.MATTE.1080p.AMZN.WEB-DL.DDP5.1.H.264-None.mkv 2023. 08. 02. 20:50 0 Aeon.Flux.2005.OPEN.MATTE.1080p.AMZN.WEB-DL.DDP5.1.H.264-None.nfo 2023. 08. 03. 19:40 <DIR> Featurettes 2023. 08. 03. 19:40 <DIR> Trailers 5 File(s) 6˙661˙091˙243 bytes Directory of e:\movies\Aeon Flux (2005)\Featurettes 2023. 08. 03. 19:40 <DIR> . 2023. 08. 03. 19:40 <DIR> .. 2022. 12. 03. 13:26 111˙613˙770 Costume Design Workshop.mkv 2022. 12. 03. 13:21 17˙020˙450 Craft of the Set - The Photographer.mkv 2022. 12. 03. 13:26 144˙010˙618 Creating A World.mkv 2023. 08. 02. 20:50 0 Creating A World.nfo 2022. 12. 03. 13:26 101˙564˙620 Locations.mkv 2023. 08. 02. 20:50 0 Locations.nfo 2022. 12. 03. 13:26 93˙184˙559 Stunts.mkv 2023. 08. 02. 20:50 0 Stunts.nfo 8 File(s) 467˙394˙017 bytes Directory of e:\movies\Aeon Flux (2005)\Trailers 2023. 08. 03. 19:41 <DIR> . 2023. 08. 03. 19:40 <DIR> .. 2022. 12. 03. 13:22 48˙012˙780 Trailer.mkv 2023. 08. 03. 19:41 0 Trailer.nfo 2 File(s) 48˙012˙780 bytes Directory of e:\movies\WarGames (1983) 2023. 08. 03. 19:40 <DIR> . 2023. 08. 03. 19:20 <DIR> .. 2023. 08. 03. 19:40 <DIR> Featurettes 2023. 08. 03. 19:40 <DIR> Trailers 2023. 08. 02. 19:32 99˙657 WarGames (1983) (2160p BluRay x265 HEVC 10bit HDR AAC 5.1 Tigole).eng.srt 2023. 08. 02. 19:31 97˙548 WarGames (1983) (2160p BluRay x265 HEVC 10bit HDR AAC 5.1 Tigole).hun.srt 2023. 08. 01. 15:45 18˙299˙218˙817 WarGames (1983) (2160p BluRay x265 HEVC 10bit HDR AAC 5.1 Tigole).mkv 2023. 08. 02. 20:40 0 WarGames (1983) (2160p BluRay x265 HEVC 10bit HDR AAC 5.1 Tigole).nfo 4 File(s) 18˙299˙416˙022 bytes Directory of e:\movies\WarGames (1983)\Featurettes 2023. 08. 03. 19:40 <DIR> . 2023. 08. 03. 19:40 <DIR> .. 2023. 08. 01. 15:17 198˙718˙312 Attack of the Hackers.mkv 2023. 08. 01. 15:17 290˙555˙845 Inside NORAD - Cold War Fortress.mkv 2023. 08. 02. 20:42 0 Inside NORAD - Cold War Fortress.nfo 2023. 08. 01. 15:17 530˙354˙522 Loading WarGames.mkv 2023. 08. 01. 15:17 190˙828˙742 Tic Tac Toe - A True Story.mkv 2023. 08. 02. 20:43 0 Tic Tac Toe - A True Story.nfo 6 File(s) 1˙210˙457˙421 bytes Directory of e:\movies\WarGames (1983)\Trailers 2023. 08. 03. 19:41 <DIR> . 2023. 08. 03. 19:40 <DIR> .. 2023. 08. 01. 15:17 43˙434˙594 Trailer.mkv 2023. 08. 03. 19:41 0 Trailer.nfo 2 File(s) 43˙434˙594 bytes Total Files Listed: 27 File(s) 26˙729˙806˙077 bytes 19 Dir(s) 3˙053˙251˙493˙888 bytes free And Emby thinks all files are new movies. Edited August 3, 2023 by MorTuadh
Solution arsim 1 Posted August 5, 2023 Solution Posted August 5, 2023 I had the same issue. It is unique to Synology. it occurs when you point Emby directly to a shared folder, not on the synology. The solution was to mount the remote folder on the synology. see this link Synology KB make sure you tick the box to mount at startup, and point the Emby library to the mount on the local synology drive.
MorTuadh 1 Posted August 5, 2023 Author Posted August 5, 2023 45 minutes ago, arsim said: I had the same issue. It is unique to Synology. it occurs when you point Emby directly to a shared folder, not on the synology. The solution was to mount the remote folder on the synology. see this link Synology KB make sure you tick the box to mount at startup, and point the Emby library to the mount on the local synology drive. Thank you so much, I managed to scan my library with this solution. "Remote CIFS shared folder" was needed for my Windows folders. 1
