lundblad 10 Posted August 2, 2023 Posted August 2, 2023 (edited) Hi! as title says, My embyserver dont download any primary covers for my movies anymore. But i get logos and backdrops and more.. but no cover, i need to add them by clicking the search button. Any ideas why ? Edited August 2, 2023 by lundblad
Luke 42245 Posted August 2, 2023 Posted August 2, 2023 Hi, where did that image come from? Can you please provide a specific example?
lundblad 10 Posted August 2, 2023 Author Posted August 2, 2023 (edited) 2 hours ago, Luke said: Hi, where did that image come from? Can you please provide a specific example? That image comes there by itself. I guess emby generates it ? For tv it works as it should Maybe i should try to remove the media library and add again ? Edited August 2, 2023 by lundblad
Solution GrimReaper 4898 Posted August 2, 2023 Solution Posted August 2, 2023 Move Screen Grabber to the bottom of preferred fetchers and Refresh metadata with Replace images selected. 1
lundblad 10 Posted August 2, 2023 Author Posted August 2, 2023 15 minutes ago, GrimReaper said: Move Screen Grabber to the bottom of preferred fetchers and Refresh metadata with Replace images selected. Oh thanks! i will try. Did not know/see i clould move them 1
