FGaray 5 Posted August 2, 2023 Posted August 2, 2023 Good afternoon to all, Server is behind a VPN with Port FWD rules configured for tcp/8090 at the VPN provider for remote connectivity. The remote clients connect but Emby things they are local. The IP address recorded is the router IP. Any suggestions on how to address this issue?
Luke 42301 Posted August 2, 2023 Posted August 2, 2023 Hi, why do you think Emby thinks things are local?
FGaray 5 Posted August 2, 2023 Author Posted August 2, 2023 The IP registered is the router IP not the endpoint WAN IP.
Luke 42301 Posted August 2, 2023 Posted August 2, 2023 It sounds like you need to configure your reverse proxy or vpn so that the server can see the original client ip addresses. Have you customized any emby server network settings?
FGaray 5 Posted August 2, 2023 Author Posted August 2, 2023 No, I have not. VPN provider moved me to a new IP yesterday and that is when I started to notice. I will reach out to them.
