Hzemby 4 Posted August 2, 2023 Posted August 2, 2023 Does decoding by Intel Quick Sync count as hardware decoding? If so, does it mean only Premiere account can use Intel QuickSync decoding? I am running Emby server on my i7-4770K (yes, almost 10-year old CPU) withtout HEVC decoding. If I upgrade to a newer Intel CPU with hardware HEVC, I still gets sofware decoding unless I upgrade to Premiere, right? (I interchangably used Quick Sync and hardware HEVC support on Intel CPU, I am not exactaly sure what the relationship is between them) Thanks
Abobader 3485 Posted August 2, 2023 Posted August 2, 2023 Hello Hzemby, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution GrimReaper 4845 Posted August 2, 2023 Solution Posted August 2, 2023 28 minutes ago, Hzemby said: Does decoding by Intel Quick Sync count as hardware decoding? It does. 29 minutes ago, Hzemby said: If so, does it mean only Premiere account can use Intel QuickSync decoding? It does. 29 minutes ago, Hzemby said: If I upgrade to a newer Intel CPU with hardware HEVC, I still gets sofware decoding unless I upgrade to Premiere, right? Right. 1
Hzemby 4 Posted August 3, 2023 Author Posted August 3, 2023 1 hour ago, Luke said: @Hzembyhave your questions been answered? Yes I got the answer from @GrimReaper, thanks! 1 1
