dondaam 0 Posted August 1, 2023 Posted August 1, 2023 I installed emby on android tv and when installing I loaded the images and content but when I exit and enter the application it comes out like this and it does not load the content or images and it doesn't just happen to me but to the users that I have on the server with android tv or firetv I add a photo of how it should look taken from the browser.
dondaam 0 Posted August 1, 2023 Author Posted August 1, 2023 every time I restart it goes like this I have to clear the cache and data and put them back for the application to work and load everything
ebr 16337 Posted August 1, 2023 Posted August 1, 2023 Hi. Make sure you are connecting with an IPv4 address not an IPv6 one.
dondaam 0 Posted August 1, 2023 Author Posted August 1, 2023 The connection is with IPv4 when setting the account to 0 it works I restart the television and the error occurs before it did not occur
Luke 42245 Posted August 1, 2023 Posted August 1, 2023 HI, what do you mean by setting the account to 0?
dondaam 0 Posted August 1, 2023 Author Posted August 1, 2023 3 minutes ago, Luke said: HI, what do you mean by setting the account to 0? I leave the server on television and add again the server and username and password only happens to me on android TV or firetv
dondaam 0 Posted August 1, 2023 Author Posted August 1, 2023 Just now, dondaam said: I leave the server on television and add again the server and username and password only happens to me on android TV or firetv That way it works for me but then he turned off the TV and it looks the same as the problem I already tried to delete the apk and reinstall on the TV and download the page that is there and it's the same
Luke 42245 Posted August 2, 2023 Posted August 2, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
dondaam 0 Posted August 2, 2023 Author Posted August 2, 2023 13 minutes ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Yes In android app it works in and in browser but in android TV it fails
Luke 42245 Posted August 2, 2023 Posted August 2, 2023 18 minutes ago, dondaam said: Yes In android app it works in and in browser but in android TV it fails Are you happy continuing to use this?
dondaam 0 Posted August 2, 2023 Author Posted August 2, 2023 5 minutes ago, Luke said: Are you happy continuing to use this? On cell phones, yes, but on Android TV it wouldn't be the same, would it?
Columbo71 0 Posted August 2, 2023 Posted August 2, 2023 17 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Is it possible to unlock the standard app? I couldn’t find a way on the shield pro. Only had the option for premiere.
Luke 42245 Posted August 17, 2023 Posted August 17, 2023 On 8/2/2023 at 3:52 PM, Columbo71 said: Is it possible to unlock the standard app? I couldn’t find a way on the shield pro. Only had the option for premiere. Hi, on mobile devices, yes. TV layouts currently requires Emby Premiere.
