carslone 2 Posted July 31, 2023 Posted July 31, 2023 As discussed on the linked thread, intros named after tags (and stored with the appropriate name in the 'Tags' directory) play in addition to the random clip from the Custom Intros directory. Similarly, as Cinema Intros can be selected for the 'Movies' and/or 'TV Episodes' content type, there is no way to apply more nuanced controls. I would like to request the ability to select which intro clips should be played/selected from based on either the library or tags. 2
GrimReaper 4902 Posted July 31, 2023 Posted July 31, 2023 You might wanna take a look at Vantage Point plugin:
unisoft 355 Posted July 31, 2023 Posted July 31, 2023 33 minutes ago, GrimReaper said: You might wanna take a look at Vantage Point plugin: This only works properly for latest updated (fixed) Emby apps when you are using TAGS. LG app 1.0.39 fixed, Apple TV fixed 1.7.4/1.7.5, Android App (latest .19 version APK on downloads area of web site). Doesn't work in GA releases of Android TV App 2.0.84 or current web app v4.7.13. On these you may get the first episodes of a series in TV actually play an intro using a TAG but rest of episodes in a series doesn't work. iOS wasn't working buy may be now - I don't currently have an iOS device as mine went wrong. But yes, Vantage Point great and I use it over the Emby build in one for both MOVIES and TV.
