jblotka 2 Posted July 30, 2023 Posted July 30, 2023 When Streaming my 4k UHD rips to the app on my S95B- using the Samsung app- I get this weird corruption throughout the playback. No error messages, It doesn't happen on my phone, but windows PC simply buffers like crazy. Thank you in advance for all that you do. ffmpeg-remux-982ea4be-a6ea-455e-9d5f-7a6dc5b2b09b_1.txt
Luke 42239 Posted July 30, 2023 Posted July 30, 2023 Hi, please attach the Emby server log as well. Thanks.
jblotka 2 Posted July 30, 2023 Author Posted July 30, 2023 (edited) 35 minutes ago, Luke said: Hi, please attach the Emby server log as well. Thanks. This is it, correct? embyserver.txt Edited July 30, 2023 by jblotka Confirmation question.
Luke 42239 Posted August 2, 2023 Posted August 2, 2023 On 7/30/2023 at 5:09 PM, jblotka said: This is it, correct? embyserver.txt 101.89 kB · 0 downloads Hi, is this the server log from when you played on the Samsung? I don't see any playback activity here. Thanks.
jblotka 2 Posted August 12, 2023 Author Posted August 12, 2023 On 8/1/2023 at 7:55 PM, Luke said: Hi, is this the server log from when you played on the Samsung? I don't see any playback activity here. Thanks. Hopefully one of these work. Sorry for the late response. embyserver (1).txt ffmpeg-remux-82d5f980-ff0c-4a3a-b0c2-f83ec10c1528_1.txt
jblotka 2 Posted August 15, 2023 Author Posted August 15, 2023 5 hours ago, Luke said: Hi, does this video have Dolby Vision? The content itself is standard HDR. The audio is dolby Atmos.
Luke 42239 Posted August 20, 2023 Posted August 20, 2023 OK that's strange. Can you provide a sample video for testing?
jblotka 2 Posted August 22, 2023 Author Posted August 22, 2023 How would I go about doing that in a way that helps you best?
jblotka 2 Posted August 22, 2023 Author Posted August 22, 2023 Upon further inspection, corruption occurs only with Disney files, both torrented and ripped. Although using emby on amazon fire TV results in perfect picture no matter publisher.
Luke 42239 Posted August 22, 2023 Posted August 22, 2023 1 hour ago, jblotka said: How would I go about doing that in a way that helps you best? dropbox or google drive would be great. thanks.
jblotka 2 Posted August 22, 2023 Author Posted August 22, 2023 3 minutes ago, Luke said: dropbox or google drive would be great. thanks. Sure thing, how do I make a sample video? Do I simply trim the .mkv?
Luke 42239 Posted August 22, 2023 Posted August 22, 2023 12 hours ago, jblotka said: Sure thing, how do I make a sample video? Do I simply trim the .mkv? Yes, just please make sure to verify that the problem also occurs with the smaller sample. Thanks !
jblotka 2 Posted August 26, 2023 Author Posted August 26, 2023 On 8/22/2023 at 10:24 AM, Luke said: Yes, just please make sure to verify that the problem also occurs with the smaller sample. Thanks ! What do you recommend for trimming the footage?
SamES 1084 Posted September 9, 2023 Posted September 9, 2023 I think this is resolved in the current beta server with newer ffmpeg, so when it becomes the standard release you might find that this doesn't occur anymore. It is/was a common issue when remuxing UHD content. Normally I would suggest that you play another audio track to avoid remuxing, but it looks like the TrueHD track is the only one in your file. You can try using this command to add an AC3 track from the TrueHD track (ignore that it says LG/DTS - it will do what you need).
jblotka 2 Posted September 9, 2023 Author Posted September 9, 2023 On 8/26/2023 at 2:46 PM, Luke said: mkvtoolnix is what i would suggest. thanks, sent that trim to you directly with google drive link
jblotka 2 Posted September 9, 2023 Author Posted September 9, 2023 10 hours ago, SamES said: think this is resolved in the current beta server with newer ffmpeg, so when it becomes the standard release you might find that this doesn't occur anymore. It is/was a common issue when remuxing UHD content. Normally I would suggest that you play another audio track to avoid remuxing, but it looks like the TrueHD track is the only one in your file. Just to clarify, changing the audio will fix the picture? The audio played fine for me, it was the picture that became corrupt somewhere between the tv receiving it and displaying it.
SamES 1084 Posted September 9, 2023 Posted September 9, 2023 7 minutes ago, jblotka said: Just to clarify, changing the audio will fix the picture? The audio played fine for me, it was the picture that became corrupt somewhere between the tv receiving it and displaying it. Correct. The audio plays fine, but it’s the process of converting the audio and putting it in a new container that’s corrupting the video. By avoiding the audio conversion from TrueHD you will avoid the video corruption Last time I tested with the beta server this problem was resolved but for now adding another audio track is your only option until the next major release.
jblotka 2 Posted September 9, 2023 Author Posted September 9, 2023 @SamESI'm stuck at finding the server system directory. I can't find it in the Emby web application. Could you provide a path for me?
Luke 42239 Posted September 10, 2023 Posted September 10, 2023 2 hours ago, jblotka said: @SamESI'm stuck at finding the server system directory. I can't find it in the Emby web application. Could you provide a path for me? What are you trying to do?
jblotka 2 Posted September 10, 2023 Author Posted September 10, 2023 On 10/26/2020 at 3:00 AM, rbjtech said: For those with the DTS problem, the best solution is to simply add a non DTS track to the original media. That way, the issues goes away and you now have a file that can be played by any system - you can opt to play the DTS Audio if you can - this script does not replace it. Go to your emby server system directory and find ffmpeg Then at a command window use the following to ADD an AC3 track and make it the default track :- ffmpeg.exe -i input.mkv -map 0:v -map 0:a:0 -map 0:a -map 0:s? -c:v copy -c:s copy -c:a copy -c:a:0 ac3 -disposition:a:0 default -disposition:a:1 0 output.mkv It copies all the existing tracks (original quality) and just adds an AC3 track, derived from the 1st Audio track. This will work on any mkv file incl 4K - it will not touch the original 'input.mkv' file. I'm trying to follow these directions. Starting with finding where to enter the code.
SamES 1084 Posted September 10, 2023 Posted September 10, 2023 2 hours ago, jblotka said: @SamESI'm stuck at finding the server system directory. I can't find it in the Emby web application. Could you provide a path for me? It depends on your operating system, but from your log file, try here /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg
jblotka 2 Posted September 10, 2023 Author Posted September 10, 2023 17 minutes ago, SamES said: It depends on your operating system, but from your log file, try here /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/ffmpeg I'm on a windows PC, running my server off a QNAP TS-453Be NAS. Apparently in order to get to the .qpkg I'd need to get root access to the NAS and that's a whole process on it's own. should I just update to Emby beta?
SamES 1084 Posted September 10, 2023 Posted September 10, 2023 54 minutes ago, jblotka said: I'm on a windows PC, running my server off a QNAP TS-453Be NAS. Apparently in order to get to the .qpkg I'd need to get root access to the NAS and that's a whole process on it's own. should I just update to Emby beta? I wouldn’t just for this. Do you have premier license? You could use the convert feature to create a copy with the original video and a new audio track.
