tomadick 8 Posted July 29, 2023 Posted July 29, 2023 (edited) Hej, how can I switch of the audio transcoding? I would like to hear the movie in 7.1 not in 5.1. Server runs on Synology. I also use Infuse on Apple TV - here 7.1 runs fine. Edited July 29, 2023 by tomadick
Luke 42239 Posted August 2, 2023 Posted August 2, 2023 Hi, you can't. The Apple TV device does not directly support True HD.
Solution tomadick 8 Posted August 3, 2023 Author Solution Posted August 3, 2023 Good morning - I found another solution: simply disable "Allow audio transcoding during media playback if necessary" and 7.1 arrives at the receiver flawlessly.
Luke 42239 Posted August 3, 2023 Posted August 3, 2023 6 hours ago, tomadick said: Good morning - I found another solution: simply disable "Allow audio transcoding during media playback if necessary" and 7.1 arrives at the receiver flawlessly. Please make sure to read the help text underneath the option. Thanks.
Luke 42239 Posted August 3, 2023 Posted August 3, 2023 6 hours ago, tomadick said: Good morning - I found another solution: simply disable "Allow audio transcoding during media playback if necessary" and 7.1 arrives at the receiver flawlessly. I'm curious about this though, can you please attach the emby server log from when you did this? Thanks.
tomadick 8 Posted August 11, 2023 Author Posted August 11, 2023 Hey, since 7.1 content via emby (with or without transcoding) always "crashes" (you can't pause, fast forward or rewind, the time stops at 0:00...) I now use Plex - there 7.1 sound runs flawlessly. Log is in the attachment. PS: When I play 7.1 content via emby, my Devon receiver also confirms that it receives 7.1 sound. embyserver.7z
Luke 42239 Posted August 19, 2023 Posted August 19, 2023 @tomadickplease let us know how things compare with Emby for Apple TV 1.7.6. Thanks !
tomadick 8 Posted August 24, 2023 Author Posted August 24, 2023 According to the interface, 7.1 is played back, but only 5.1 arrives at the receiver...
Luke 42239 Posted August 25, 2023 Posted August 25, 2023 12 hours ago, tomadick said: According to the interface, 7.1 is played back, but only 5.1 arrives at the receiver... And it's direct playing?
