demian42 1 Posted July 29, 2023 Posted July 29, 2023 Hi - i can not load plugin catalog. I have tried different browsers and from a phone and from a computer all on same network as server. If helpful or related, metadata stopped updated. Logs pasted below. 2023-07-29 06:24:19.990 Error Server: Error processing request *** Error Report *** Version: 4.7.13.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.1.38-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #2 SMP PREEMPT_DYNAMIC Mon Jul 10 09:50:25 PDT 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 24 Data path: /config Application path: /system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Name or service not known (www.mb3admin.com:443) ---> System.Net.Sockets.SocketException (0xFFFDFFFF): Name or service not known at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackages(CancellationToken cancellationToken, Boolean withRegistration, String packageType, Version applicationVersion) at Emby.Api.PackageService.Get(GetPackages request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: Name or service not known Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
Neminem 1626 Posted July 29, 2023 Posted July 29, 2023 What happens when you access www.mb3admin.com from a browser ? Do you have VPN, firewall or something like it ?
demian42 1 Posted July 29, 2023 Author Posted July 29, 2023 Works fine. So I have a pfsense router / firewall but nothing special. The emby server is on an emby docker, plex updates metadata without trouble and I have an NZB solution on a docker that accesses the internet all the time. And emby itself updates over the internet without trouble. Accessing www.mb3admin.com redirects to emby.media ....
ebr 16346 Posted July 29, 2023 Posted July 29, 2023 Hi. Something is blocking the server's access or, possibly, incorrect DNS configuration. 1
Neminem 1626 Posted July 29, 2023 Posted July 29, 2023 (edited) OK another test mb3admin.com/admin/service/EmbyPackages.json Be sure to run this from the server. Should show something like this. Edited July 29, 2023 by jaycedk
ebr 16346 Posted July 29, 2023 Posted July 29, 2023 3 minutes ago, jaycedk said: OK another test mb3admin.com/admin/service/EmbyPackages.json Be sure to run this from the server. Hi. Bringing that up in a browser will not necessarily confirm anything as firewalls and other security software block/allow by process.
ebr 16346 Posted July 29, 2023 Posted July 29, 2023 Its still not a terrible idea to try as, if that fails, then we know there is a very high-level network issue. It just won't be definitive as far as whether or not the server can reach the same destination. Thanks.
GrimReaper 4913 Posted July 29, 2023 Posted July 29, 2023 3 hours ago, demian42 said: System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: Name or service not known 18 minutes ago, demian42 said: The emby server is on an emby docker Similar reported in the past, might be caused by server starting up before the network fully initialized, try adding a docker startup delay. 1
Rock1m1 2 Posted June 27, 2024 Posted June 27, 2024 (edited) I have the same issue, plugins catalog page does not show anything other then the loading icon. I even recently got a fixed ip from my ISP to help me better connect to my media library from the internet, but in this case in does not seam to help. UPDATE: Changing DNS fixed it for me. I just used Warp's DNS feature to change it to 1.1.1.1 and it worked. Once installed I went back to the old DNS and it still works. Edited June 27, 2024 by Rock1m1 1
AngelMovies 0 Posted December 17, 2024 Posted December 17, 2024 Mudei os DNSs para 8.8.8.8 e 8.8.4.4 respectivamente e funcionou...
