mireki1975 4 Posted July 29, 2023 Posted July 29, 2023 my emby and tvheadend installation runs under unRaid. now i managed to add my m3u to emby. when i want to play a channel it says „no compatible streams found“ i read some stuff with ffmpeg but i now sure how it works in a Docker Container. Containers are all up to date and transcoding is working fine with my own videos. PVR has worked a year ago with the same Hardware. log below Spoiler 2023-07-29 12:11:32.016 Info App: User policy for admin. EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2023-07-29 12:11:32.090 Info LiveTvManager: Opening channel stream, external channel Id: a127cbf9dfda41e5afed1139a6b6ccb4_1029274355 2023-07-29 12:11:32.092 Info LiveTV: Streaming Channel a127cbf9dfda41e5afed1139a6b6ccb4_1029274355, with streamId: tvh_1029274355 2023-07-29 12:11:32.106 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://localhost:9981/x_path1_x/x_path2_x/x_path3_x?ticket=13e300a04832c7c19e1c3dc3d89ccb9e04ba9123 2023-07-29 12:11:32.107 Info HttpClient: GET http://localhost:9981/x_path1_x/x_path2_x/x_path3_x?ticket=13e300a04832c7c19e1c3dc3d89ccb9e04ba9123 2023-07-29 12:11:37.115 Info HttpClient: Http response 401 from http://localhost:9981/x_path1_x/x_path2_x/x_path3_x?ticket=13e300a04832c7c19e1c3dc3d89ccb9e04ba9123 after 5008ms. HeadersServer=HTS/tvheadend, Cache-Control=no-cache, WWW-Authenticate=Digest realm="tvheadend", qop=auth, nonce="LY13AV4wew67vdcItpRKvB/rBaxV8xVTcV5kZfElZ7g=", opaque="3tCuyNO20O9lZdKUe/PRgTr/np4n5EMmIWTagW4RhDo=", Connection=close 2023-07-29 12:11:37.120 Error LiveTV: Error in GetChannelStreamWithDirectStreamProvider *** Error Report *** Version: 4.7.13.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.1.38-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #2 SMP PREEMPT_DYNAMIC Mon Jul 10 09:50:25 PDT 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.Open(CancellationToken openCancellationToken) at MediaBrowser.Controller.LiveTv.BaseTunerHost.GetChannelStream(TunerHostInfo tuner, BaseItem dbChannnel, String tunerChannelId, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2023-07-29 12:11:37.121 Error MediaSourceManager: Error opening live stream *** Error Report *** Version: 4.7.13.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.1.38-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #2 SMP PREEMPT_DYNAMIC Mon Jul 10 09:50:25 PDT 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2023-07-29 12:11:37.125 Error Server: Error processing request *** Error Report *** Version: 4.7.13.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.1.38-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #2 SMP PREEMPT_DYNAMIC Mon Jul 10 09:50:25 PDT 2023 Framework: .NET 6.0.14 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStream(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.OpenMediaSource(OpenMediaSource request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2023-07-29 12:11:37.127 Info Server: http/1.1 Response 500 to host1. Time: 10463ms. http://192.168.178.3:8096/emby/Items/1726633/PlaybackInfo?UserId=870a1716b1044e8c9188fbf1a8117c63&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Safari macOS&X-Emby-Device-Id=cd05b347-adf7-4714-9116-db132de10399&X-Emby-Client-Version=4.7.13.0&X-Emby-Language=de&reqformat=json
Luke 42242 Posted July 29, 2023 Posted July 29, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
mireki1975 4 Posted July 30, 2023 Author Posted July 30, 2023 i really dont know why but its working now i tried to get the full log etc and it works PVR is always strange in emby :.) 1
