Riptide126 24 Posted July 28, 2023 Posted July 28, 2023 Hi, so there is one show I have in emby where it lists the language of the audio as japanese but the audio is actually chinese, I am not sure the best way to fix this.
pwhodges 2023 Posted July 28, 2023 Posted July 28, 2023 You can't do it in Emby, as the information is in the file itself. Use MKVToolNix to remux the file with the correct language descriptor, or (if it's already in MKV format) use jMkvPropEdit to change the flag in the file directly. Paul 1
Luke 42185 Posted July 29, 2023 Posted July 29, 2023 That’s correct. How is the track tagged within the file?
Riptide126 24 Posted August 12, 2023 Author Posted August 12, 2023 Sorry for the delayed response, I fixed it by using the tool that was recommended for it so I am all good 1
