Logitech Harmony 1100 with external PDVD14
Hi everyone!
I'm using Media Browser Classic for my HTPC control by remote harmony 1100 (imon inside for IR), this is working perfectly on Media Browser with all functions.
Now im using PowerDVD14 for external play iso and all good but only the functions on left can't use (see on picture) like "stop" "play" "rewind" "fast forward"
any suggestions? Thanks all
Finally, i found how to fix it. Tks all
Pls, delete this topic. Tks Ad
swhitmore
Please post your fix in case anyone else has the same issue.
Open iMON Manager then do these step
Add Program
C:\Program Files (x86)\CyberLink\PowerDVD14
Add Macro Command:
Shortcut should be same as programs (PowerDVD; TMT...)
This I did for PowerDVD 14
