tomadick 8 Posted July 22, 2023 Posted July 22, 2023 Hi there, can I somehow change the order of the channels from my favorites on the home page? I have already assigned the channels their own channel numbers, but unfortunately in AppleTV they have no effect on the order in the tv guide, for example.
ebr 16334 Posted July 22, 2023 Posted July 22, 2023 Hi. What sort order have you selected in the guide screen?
tomadick 8 Posted July 23, 2023 Author Posted July 23, 2023 In the AppleTV app, there are no options in the TV Guide to set the sorting. For channels, I have "Favorites, then by channel number" and everything is sorted correctly there. In the Android app and also on the web application (via Synology) the sorting works with the above mentioned setting as I want it. On the photo.from the TV Guide you can see very nicely my self-assigned channel numbers, they are not observed at all.
Luke 42240 Posted July 27, 2023 Posted July 27, 2023 hi, we'll take a look at it. Thanks for reporting.
