Capitano 4 Posted February 13, 2024 Posted February 13, 2024 Installed the CoverArt plugin. Resources doesn't seem to load. From logs: The version of the native libSkiaSharp library (80.2) is incompatible with this version of SkiaSharp. Supported versions of the native libSkiaSharp library are in the range [88.1, 89.0). embyserver.txt
Luke 42251 Posted February 13, 2024 Posted February 13, 2024 3 hours ago, Capitano said: Installed the CoverArt plugin. Resources doesn't seem to load. From logs: The version of the native libSkiaSharp library (80.2) is incompatible with this version of SkiaSharp. Supported versions of the native libSkiaSharp library are in the range [88.1, 89.0). embyserver.txt 80.55 kB · 2 downloads Hi, how did you install Emby Server?
Capitano 4 Posted February 14, 2024 Posted February 14, 2024 20 hours ago, Luke said: Hi, how did you install Emby Server? UnRaid - docker
Capitano 4 Posted February 14, 2024 Posted February 14, 2024 10 hours ago, Capitano said: UnRaid - docker Todays update to Emby solved the issue - thanx.
Luke 42251 Posted February 14, 2024 Posted February 14, 2024 OK that wasn't us. That's from whoever is packaging it for Unraid. But glad it's working for you now.
hstamas 179 Posted February 21, 2024 Author Posted February 21, 2024 On 7/26/2023 at 6:02 PM, Luke said: Hi, we are looking into it. Thanks. This ever get updated to work with Apple Silicon @Luke?
Luke 42251 Posted February 21, 2024 Posted February 21, 2024 5 hours ago, hstamas said: This ever get updated to work with Apple Silicon @Luke? HI, yea please try with the latest versions and report your experience. Thanks.
hstamas 179 Posted February 28, 2024 Author Posted February 28, 2024 On 2/21/2024 at 3:04 PM, Luke said: HI, yea please try with the latest versions and report your experience. Thanks. Seems to be working! Thanks! 1
Testfor69 21 Posted June 24, 2025 Posted June 24, 2025 Hey, One Question, had somone a Cover for `Movie-3D`to use it as custom Profil ? Thanks
Testfor69 21 Posted July 1, 2025 Posted July 1, 2025 Good morning, Maybe Cover Art 4.0 needs a small update, it does not put the TEXT on every cover, although it is always the same codec. Or am I doing something wrong...?
Luke 42251 Posted July 1, 2025 Posted July 1, 2025 15 hours ago, Testfor69 said: Good morning, Maybe Cover Art 4.0 needs a small update, it does not put the TEXT on every cover, although it is always the same codec. Or am I doing something wrong...? hi, are you sure that emby server has detected all of those as 3D? 1
Testfor69 21 Posted July 1, 2025 Posted July 1, 2025 1 hour ago, Luke said: hi, are you sure that emby server has detected all of those as 3D? I think so, because these all the same Codec (H264) not different Codecs and SBS...
Luke 42251 Posted July 1, 2025 Posted July 1, 2025 1 hour ago, Testfor69 said: I think so, because these all the same Codec (H264) not different Codecs and SBS... Did you check the metadata editor? 1
Testfor69 21 Posted July 2, 2025 Posted July 2, 2025 Evening, yes I have with medinfo, as I said, both or all are always the same codecs...There are no other media (codecs) than SBS. Can you make a screen of a movie where it shows it and one where it doesn't show it...maybe I'm missing something... Thanks for the answer...
ebr 16339 Posted July 2, 2025 Posted July 2, 2025 23 minutes ago, Testfor69 said: yes I have with medinfo Hi. He means use the "Edit metadata" menu item on one of those items not showing the 3D text. Does that indicate that the item is 3D? 1
Testfor69 21 Posted July 3, 2025 Posted July 3, 2025 19 hours ago, ebr said: Hi. He means use the "Edit metadata" menu item on one of those items not showing the 3D text. Does that indicate that the item is 3D? Ah, ohkai, nope, it's not displayed as 3D.... But the same DAtei, (codec) only different movie, is shown to me as HSBS Thanks, then I'll edit all the ones where it's not displayed...;)...thanks for the solution @ebr& @Luke!!!! 1
horstepipe 423 Posted September 21, 2025 Posted September 21, 2025 Is support for the new Web Streams plugin planned?
Luke 42251 Posted September 21, 2025 Posted September 21, 2025 26 minutes ago, horstepipe said: Is support for the new Web Streams plugin planned? To do what exactly ?
horstepipe 423 Posted September 21, 2025 Posted September 21, 2025 1 hour ago, Luke said: To do what exactly ? to make specific covers for web stream sources to better distinguis them from local / own sources.
Luke 42251 Posted September 21, 2025 Posted September 21, 2025 11 hours ago, horstepipe said: to make specific covers for web stream sources to better distinguis them from local / own sources. Where would you need to do that other than search?
horstepipe 423 Posted September 22, 2025 Posted September 22, 2025 (edited) 21 hours ago, Luke said: Where would you need to do that other than search? exactly, if users search for shows it is hard or impossible to see where the content comes from, e.g. here for "Terra X" Edited September 22, 2025 by horstepipe 1
Seger 123 Posted October 3, 2025 Posted October 3, 2025 (edited) Hello everyone my friends@Luke Like many others, I have noticed margins in the scaling, but only with my BoxSets. I read the thread carefully and understood that it was related to the calculation for individual clints and a change in how the Emby server processes images and how the CoverArt plugin handles it. Just ignore it if I got it all wrong :-). Is there a solution to this problem and if so, what should I do? I had the images regenerated years ago and had to delete meta images locally. Do I have a possibility and if so, only for the BoxSets? Current Emby Stable 4.9.1.80, in this context again a big thank you to all developers and the whole community, sensational - I'm already looking forward to the next stable which my Docker variant: https://hub.docker.com/r/rajiska/emby-n150-fixed/tags (incl. hardware support Intel® Arc™ 140T GPU, will replace. @Ra'Jiska , thanks again for your build!!! Thank you and best regards, Seger Edited October 3, 2025 by Seger
GrimReaper 4907 Posted October 3, 2025 Posted October 3, 2025 3 hours ago, Seger said: Do I have a possibility and if so, only for the BoxSets? For local Web app, you can do it via Custom CSS (well, at least something). For other client apps - unfortunately no solution exists currently. 1
Seger 123 Posted October 3, 2025 Posted October 3, 2025 @GrimReaper, You got that heart under the post, but wanted to get rid of another smile, which didn't go - then on this way - FYI @Luke
GrimReaper 4907 Posted October 3, 2025 Posted October 3, 2025 (edited) 3 hours ago, Seger said: @GrimReaper, You got that heart under the post, but wanted to get rid of another smile, which didn't go - then on this way - FYI @Luke Yeah, got my own gripes with it, noticed it first some time ago in the Android app (my treatments were squashed compared to yours squeezed) and later spreading into Web app as well and it looks hideous, like a poke in the eye. It annoyed me so much that I've ultimately disabled CoverArt treatment - and that should not be the solution, but currently there isn't any other. Edited October 3, 2025 by GrimReaper
