Maurod97 1 Posted July 17, 2023 Posted July 17, 2023 Hi, Recently I bought a premium Emby subscription on decided to try hardware transcoding, after setting it up I give it a go but sadly some files doesn't start playing at all and the ones who do start only plays for about 10 seconds afterwards they stop. I tried to lower the quality and that way they play normally, but I would like to avoid that and always use the highest quality possible. I never had this issue before, without HW transcoding. I have Emby running on a docker container using the official image, the latest version. I can provide more information about the Docker setup if needed.p The server where Docker is running has a i7-10710U Processor, 16 gb of ram and a 500 gb SSD. Here's the server and ffmpeg log. Please let me know what other information I can provide! Thanks! embyserver.txt ffmpeg-transcode-62d0979d-8c11-43f4-bb36-4ed28f11f286_1.txt
Maurod97 1 Posted July 17, 2023 Author Posted July 17, 2023 Here's another ffmpeg log with another file in case it helps ffmpeg-transcode-ca9abd0b-4f97-4716-b806-5f9c27004097_1.txt
Schleudertrauma 10 Posted July 21, 2023 Posted July 21, 2023 Have you set up docker or your docker container in that way that it has access to hardware resources and drivers from the host system?
Maurod97 1 Posted July 21, 2023 Author Posted July 21, 2023 54 minutes ago, Schleudertrauma said: Have you set up docker or your docker container in that way that it has access to hardware resources and drivers from the host system? I believe so Here's the content of my docker compose file. emby: image: emby/embyserver container_name: emby restart: unless-stopped environment: - UID=1000 - GID=100 - GIDLIST=106 - TZ=Europe/Madrid networks: - caddy ports: - 8096:8096/tcp devices: - /dev/dri/renderD128:/dev/dri/renderD128 - /dev/dri/card0:/dev/dri/card0 volumes: - /home/server/.config/emby/:/config - /home/server/ext/data/media:/data/media And the content of `/dev/dri` ➜ ls -la /dev/dri total 0 drwxr-xr-x 3 root root 100 Jul 15 13:45 . drwxr-xr-x 17 root root 3280 Jul 15 14:29 .. drwxrwxrwx 2 root root 80 Jul 15 13:45 by-path crwxrwxrwx 1 root video 226, 0 Jul 15 13:45 card0 crwxrwxrwx 1 root render 226, 128 Jul 15 13:45 renderD128
Schleudertrauma 10 Posted July 21, 2023 Posted July 21, 2023 Hmm, I would try to lower the bitrate in network settings. I had that problem too that relatively often emby suddenly stopped playback due to no reason and i couldn't find anything in my logs. @Luketold me to lower the rate. I also set the h264 encoding to fast and 265 too and since then i have nearly 0 problems with playback. Not the best way i know but that's it. I saw that you're using an Intel iHD driver for Intel(R) Gen Graphics. Is that powerful enough to handle those 4k streams like them in your logs? I'm sorry that i can't give you real technical support, i can only tell you how i solved this problem in my case. You could set the log setting to "Debug" and then try again for a several time and pay attention whether the playback failes randomly on all of your media or reproducable on selective ones and then you can post the "Debug" log in here but be aware that in case you restart emby or the host, the log settings will be reset to default.
Maurod97 1 Posted July 22, 2023 Author Posted July 22, 2023 I did a bunch of tests, here the conclusions I got. 1. 4k files with subtitles doesn't work even if I lower the bitrate 2. 4k files without subtitles doesn't work with the bitrate and resolution setting as auto, in my case 4K - 140 Mbps - This is the case in the logs above 3. 4k files without subtitles with bitrate and resolution downgraded works, up to 4K - 100 Mbps, higher than that the stream stops after 10-20 seconds. 4. 4k files completely disabling subtitle stream using the Diagnostic Options plugins with bitrate and resolution set to auto stops as well 5. 1080p files doesn't work with subtitles if I leave the bitrate and resolution to auto 6. 1080p files without subtitles appears to work correctly 7. 1080p files with subtitles and lower bitrate and resolutions appears to work I can provide logs for each test case if needed. The common issue I see in the logs is this lines 11:05:49.592 [matroska,webm @ 0x1a24840] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options I believe it's related to the subtitles. Not sure if the iGPU is powerful enough but I never had issues with software transcoding streaming the same files. Thanks! I really appreciate your help hopefully @Lukecan provide more information.
Luke 42245 Posted August 26, 2023 Posted August 26, 2023 Has the 4.7.14 update helped? Beyond that I think there's a good chance this is improved in the upcoming 4.8 release. Thanks.
Maurod97 1 Posted September 11, 2023 Author Posted September 11, 2023 Hi, I been trying the 4.8 beta and it's much better, a little stutter, but if I leave loading for a few minutes it appears to work perfectly. I'll do more extensive tests and let you know. Thanks! 1
