I have reviewed the guide, and to merge identical movies, the files need to be named according to the following requirements.
/Movies
  /300 (2006)
  /300 (2006)/300 (2006) - 1080p.mkv
  /300 (2006)/300 (2006) - 4K.mkv
But there are other files within the folder where I store movies, and it would be inconvenient to put different versions of the same movie in one folder. Can emby add a feature to merge folders based on similar folder names? As shown below.
/Movies
  /300 (2006)
  /300 (2006)/300 (2006) - 1080p/movies.mkv
  /300 (2006)/300 (2006) - 4K/movies.mkv
Thanks!
Junglejim
/Movies
  /300 (2006)
/Movies
  /300 (2006)
Thanks!
Hi mate, check out here..
Not sure if this is what your after bur it's worth a look. ;)
I have tried this plugin, and I'm not sure if my version is correct because it didn't merge the same movies after installation.
Junglejim
Ok. I haven't tried it myself to be honest. I don't have multi versions of movies. I thought it could help.
Maybe post a question in the "Automatic version grouping for movies" thread, I'm sure someone will help you out! :)
Give them some info like.. server version etc..
Edited by Junglejim
