Rudig 0 Posted November 1, 2014 Posted November 1, 2014 Hi Griffo, do you by any chance still have this .ts buffer file present? Would be good to analyse why ffmpeg is having issues reading it.
tompa 0 Posted November 1, 2014 Posted November 1, 2014 (edited) Ok, here are my logs. Argus stream starts and then stops again. /tompa logs_4.zip Edited November 1, 2014 by tompa
Rudig 0 Posted November 1, 2014 Posted November 1, 2014 (edited) Hi Sven, is it possible that the stream isn't kept alive properly which tranlates in ffmpeg stating that the file either can't be read or has invalid data in it? Edited November 1, 2014 by Rudig
Griffo 3 Posted November 1, 2014 Posted November 1, 2014 Hi Sven, is it possible that the stream isn't kept alive properly which tranlates in ffmpeg stating that the file either can't be read or has invalid data in it? I think they may be happening. I tried to capture the .ts file but it is barely created when Argus deletes it. From the ARgus Logs 2014-11-02 09:29:24.3644 [info ][3]: AddStream: file = "c:\timeshift\Card4-1-0.ts.tsbuffer", stream= "rtsp://VAULT:8554/stream-live-4-1" 2014-11-02 09:29:27.5050 [info ][3]: RemoveStream: rtspUrl= "stream-live-4-1" 2014-11-02 09:29:31.5207 [info ][3]: AddStream: file = "c:\timeshift\Card4-1-0.ts.tsbuffer", stream= "rtsp://VAULT:8554/stream-live-4-1" 2014-11-02 09:29:33.3019 [info ][3]: RemoveStream: rtspUrl= "stream-live-4-1" Argus and MB logs attached GriffoLogs.zip
Rudig 0 Posted November 2, 2014 Posted November 2, 2014 Hi Griffo, Not sure if this is possible but can we get the most extensive logging from Argus? Perhaps it states in logging which proces terminates the stream
Griffo 3 Posted November 2, 2014 Posted November 2, 2014 I've tried to turn up logging to debug, not sure it revealed anything. Have to run but will try playing with debug options more later. transcode-a7a8fc25-13ad-441b-b488-d4d496e26612.zip
Rudig 0 Posted November 2, 2014 Posted November 2, 2014 Thanks for these files, in the recorder_REST.log it seems a heartbeat is in place for a stream 2014-11-02 20:21:15.6215 [info ][19]: REST PUT /Callback/Heartbeat/1e580c63-52db-11e4-80bc-38eaa7abfd4c But that stream doesn't appear anywhere in the other logging. Also the stream which is active doesn't seem to have a heartbeat active. @@Sven, could this be the issue? No heartbeat thus a dieing stream which in turn makes it impossible to transcode since there is nothing to transcode?
Sven 136 Posted November 2, 2014 Posted November 2, 2014 Thanks for these files, in the recorder_REST.log it seems a heartbeat is in place for a stream But that stream doesn't appear anywhere in the other logging. Also the stream which is active doesn't seem to have a heartbeat active. @@Sven, could this be the issue? No heartbeat thus a dieing stream which in turn makes it impossible to transcode since there is nothing to transcode? The heartbeat is not sent to argus?
Rudig 0 Posted November 2, 2014 Posted November 2, 2014 (edited) It's not? What triggers Argus to stop a certain stream? Edited November 2, 2014 by Rudig
Sven 136 Posted November 2, 2014 Posted November 2, 2014 I also see some "Not Supported" coming back from Argus in the MB logging....
Rudig 0 Posted November 2, 2014 Posted November 2, 2014 (edited) @@Sven, If I look into the REST API of Argus I see the following: Post/KeepLiveStreamAliveKeep live stream aliveDescriptionTell the recorder we are still showing this stream and to keep it alive. Call this every 30 seconds or so.Post DataPost data is the live stream entity of the stream to keep alive.Parameter Format DescriptionChannel Channel The channel being streamed.RecorderTunerId Guid The ID of the recorder this stream is running on.CardId string The unique ID of the recorder's card that is being used for the streaming (if provided by the recorder).RtspUrl string The rtsp URL to the stream.TimeshiftFile string The UNC path to a timeshift file of the live stream (if available).StreamStartedTime /Date(gmt_ms+HHmm)/ The date and time the stream was first started.StreamLastAliveTimeUtc /Date(gmt_ms)/ The date and time the stream was last sent a keep-alive signal (UTC).Show JSON exampleReturnsReturns true if the live stream is still running, false otherwise.Show JSON example Is this keepalive action done by you? @@Griffo, can you traceback in your logging, who started stream 1e580c63-52db-11e4-80bc-38eaa7abfd4c? Was that mediabrowser or just a scheduled job within Argus? Edited November 2, 2014 by Rudig
Sven 136 Posted November 2, 2014 Posted November 2, 2014 (edited) Yes i do that. But i am changing some stuff. To do it on a more proper way... Edited November 2, 2014 by Sven
Sven 136 Posted November 2, 2014 Posted November 2, 2014 The problem with timeshifting is the container "tsbuffer". I think @@Luke told me a while ago that this was not yet possible.. It's "tsbuffer" because it could me more files. A recording is "ts" and that is not a problem. The "LAG,blocks,.." on the rtsp is also a good question. But i am not a real transcoding expert, so...
Rudig 0 Posted November 2, 2014 Posted November 2, 2014 (edited) The ts buffer file can indeed be switching to another file so perhaps rtsp is the way to go. From what I read about ffmpeg it should be able to use rtsp as input, but I've never tried that. edit1: Tried to use the RTSP stream from Argus as input for FFMPEG, and it worked :-) really cool to be honest. I copied the RTSP string that Argus gives in the RTSP logfile into my FFMEG parameters and it started to use that as input. Works pretty well. Hopefully we can test this some more and use this to bypass the tsbuffer file issues Edited November 2, 2014 by Rudig
Sven 136 Posted November 2, 2014 Posted November 2, 2014 You can test it. By unchecking the timeshift option. That is/was already rtsp. But we have many LAG,blocks on that...
pünktchen 1411 Posted November 2, 2014 Author Posted November 2, 2014 @@Sven, with version 1.0.5418.16361 of your plugin streaming is totally broken for me I can see in the Argus Scheduler Console how the stream gets started and is immediately stopped. Also the "timeshift" option does not get stored. https://www.dropbox.com/s/q6h0lcpy550cu3k/logs.rar?dl=0
Sven 136 Posted November 2, 2014 Posted November 2, 2014 As i can see in your transcode logs, you are using timeshifting. But that doesn't work (he doesn't know the tsbuffer format)
pünktchen 1411 Posted November 2, 2014 Author Posted November 2, 2014 (edited) Mmh, but when i look in the plugin settings again the checkbox for timeshifting is not active Nevertheless with or without this option, it makes no difference. The stream starts and stops immediately. To be more exact it starts and always stops twice! (start-stop-start-stop) A question apart from streaming problems: Every time i restart MBS the guide is empty although i have deactivated the task to clean the tv database. Isn't there a cache? Edited November 2, 2014 by pünktchen
Griffo 3 Posted November 3, 2014 Posted November 3, 2014 @@Sven, If I look into the REST API of Argus I see the following: Is this keepalive action done by you? @@Griffo, can you traceback in your logging, who started stream 1e580c63-52db-11e4-80bc-38eaa7abfd4c? Was that mediabrowser or just a scheduled job within Argus? I've attached new logs below. To avoid any confusion, i deleted all scheduled recordings, and restarted both Argus and MB3 to get fresh clean logs. Nothing else is being done on these boxes as they are a test setup. So whatever is in the logs is from me clicking on LiveTV in MB in Chrome. Just to touch on FFMPEG - personally I could care less about live transcoding of live TV, give it to me as a raw stream please and let my server CPU cycles do something more useful. If you could do that, then I could finally get rid of MediaPortal and just use MBT for everything (once it's stable that is). I've noticed that currently MBT tries to get transcoded TV rather than raw currently. GriffoLogs.zip
Rudig 0 Posted November 3, 2014 Posted November 3, 2014 (edited) Griffo thanks again for these logs. Couple of strange things appear, stream is started and within a second its also stopped: from recorder.log 2014-11-03 13:04:26.4109 [info ][Recorder]: TuneLiveTvStream(): tuning card #4 to SBS ONE2014-11-03 13:04:26.4265 [info ][Recorder]: Starting live stream on card #4, service SBS ONE in 'c:\timeshift\'2014-11-03 13:04:31.0203 [info ][Recorder]: Live streaming of SBS ONE started on card #4, stream 51e1c305-5ec0-4588-9405-bf2dc79003ab2014-11-03 13:04:32.8640 [info ][Recorder]: Stopping stream 51e1c305-5ec0-4588-9405-bf2dc79003ab on card #42014-11-03 13:04:33.0828 [info ][Recorder]: Stream 51e1c305-5ec0-4588-9405-bf2dc79003ab stopped Heartbeat is sent for a stream that doesn't appear in logging as started: recorder_rest.log 2014-11-03 13:01:32.0244 [info ][9]: REST PUT /Callback/Heartbeat/1e580c64-52db-11e4-80bc-38eaa7abfd4cstatus: OK The ID that we have a heartbeat requested for also appears as service from the EPG as seen in recorder_rest.log 2014-11-03 13:01:47.1654 [info ][10]: REST GET /Callback/Epg/NextServiceToGrab/1e580c64-52db-11e4-80bc-38eaa7abfd4c @@Griffo, no transcoding would be fine for some clients, but my ipad mini (1st gen) can't decode the raw dvb-c streams live. So for an ipad (and probably a lot of other devices) transcoding is needed @@Sven, the errors you get from ffmpeg when transcoding a RTSP stream only appear in the first few seconds right? Isn't that because it dives into a DVB-C stream in the middle and than gets a lot of garbage, there is a certain frame in this stream after which ffmpeg works perfect for me, I'll try to find the name of the frame. Looking at some code I've got some questions on whether I understand what is happening, looking at this from livetvservices.cs public async Task<ChannelMediaInfo> GetChannelStream(string channelOid, CancellationToken cancellationToken){_logger.Info(string.Format("[ArgusTV] Start GetChannelStream Async for ChannelId: {0}", channelOid));await EnsureConnectionAsync(cancellationToken);try{var channel = Proxies.SchedulerService.GetChannelById(Guid.Parse(channelOid)).Result;var result = Proxies.ControlService.TuneLiveStream(channel, null).Result;LiveStream liveStream = result.LiveStream;if (result.LiveStreamResult == LiveStreamResult.Succeeded){_liveTvTimer.Enabled = true;return new ChannelMediaInfo{Id = channelOid,Path = liveStream.RtspUrl,Protocol = MediaProtocol.Rtsp,//Path = liveStream.TimeshiftFile};}}catch (Exception ex){_logger.Error(string.Format("[ArgusTV] GetChannelStream async for ChannelId: {0} with exception: {1}", channelOid ,ex.Message));}throw new ResourceNotFoundException(string.Format("Could not stream channel {0}", channelOid));} Specifically: {Id = channelOid,Path = liveStream.RtspUrl,Protocol = MediaProtocol.Rtsp,//Path = liveStream.TimeshiftFile}; The channelOid doesn't relate back to the rest-api related to /TuneLiveStream. /TuneLiveStream gives back for example: {"LiveStreamResult":0,"LiveStream":{"Channel":{"ChannelId":"2276c60d-703c-409d-a094-3c66247e23c9","Id":0,"GuideChannelId":"3295acfb-4903-4248-b2ec-24efe0b73f1f","ChannelType":0,"DisplayName":"text","LogicalChannelNumber":0,"VisibleInGuide":false,"DefaultPreRecordSeconds":0,"DefaultPostRecordSeconds":0,"BroadcastStart":"text","BroadcastStop":"text","Sequence":0,"Version":0},"RecorderTunerId":"333fe7cd-32c6-47c4-a25a-60ea754868bb","CardId":"text","RtspUrl":"text","TimeshiftFile":"text","StreamStartedTime":"\/Date(1297293089984+0200)\/","StreamLastAliveTimeUtc":"\/Date(1297293089984+0200)\/"}} My guess would be that the keep alive event should sent : RecorderTunerId as the Id for the stream, and not the Channel ID that we saw before. Is my understanding correct? Edited November 3, 2014 by Rudig
Sven 136 Posted November 3, 2014 Posted November 3, 2014 Griffo thanks again for these logs. Couple of strange things appear, stream is started and within a second its also stopped: from recorder.log Heartbeat is sent for a stream that doesn't appear in logging as started: recorder_rest.log The ID that we have a heartbeat requested for also appears as service from the EPG as seen in recorder_rest.log @@Griffo, no transcoding would be fine for some clients, but my ipad mini (1st gen) can't decode the raw dvb-c streams live. So for an ipad (and probably a lot of other devices) transcoding is needed @@Sven, the errors you get from ffmpeg when transcoding a RTSP stream only appear in the first few seconds right? Isn't that because it dives into a DVB-C stream in the middle and than gets a lot of garbage, there is a certain frame in this stream after which ffmpeg works perfect for me, I'll try to find the name of the frame. Looking at some code I've got some questions on whether I understand what is happening, looking at this from livetvservices.cs Specifically: The channelOid doesn't relate back to the rest-api related to /TuneLiveStream. /TuneLiveStream gives back for example: My guess would be that the keep alive event should sent : RecorderTunerId as the Id for the stream, and not the Channel ID that we saw before. Is my understanding correct? That's not the latest code I am testing with. I have some other code in my fork and also local...
Rudig 0 Posted November 3, 2014 Posted November 3, 2014 (edited) Hmmm thats not really helpfull :-) What about the transcoding remarks? Edited November 3, 2014 by Rudig
Sven 136 Posted November 3, 2014 Posted November 3, 2014 Voila latest source is online in my fork.... When we have an error with ffmpeg the stream is closed directly...
Griffo 3 Posted November 4, 2014 Posted November 4, 2014 (edited) I notice that Argus creates 3 files - the .tsbuffer, a .ts1.ts and a .ts2.ts. The .tsbuffer is only 1KB in size. If I point FFMPEG at it, it errors out. If I point it at a .ts1.ts file it converts fine. Maybe we need to use RTSP? Or insert something like tsreader to read the stream properly? I looked at the MP and XBMC plugins for argus, and both projects use MP's tsreader to open the stream. Edited November 4, 2014 by Griffo
tompa 0 Posted November 4, 2014 Posted November 4, 2014 Would it make sense to change timeshift buffer to one file for testing purpose? Its possible if needed. /tompa
