dynamohum 4 Posted July 14, 2023 Posted July 14, 2023 hey guys, this may well be a local issue but I've had a good root around and not come up with anything. Basically in the web client I'm only seeing guide data for the first 28 channels. I use an HDHomeRun CONNECT Quatro as my feed - Freeview over antenna in the NW UK. Emby server running on Linux:4.8.0.39 beta snippet of what was discovered in the logs: # grep Found\ epg\ channel embyserver.txt 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT BBC1LDN 30644 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT ITV1LON 17468 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT BBC2 17154 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT C4 17155 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT CH5 17157 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT ITVTHREE 44643 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT BBCNEWS 19037 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT DRAMAUK 82575 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT ITV2 20630 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT E4 25117 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT CBEEB 29325 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT FILM4UK 21494 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT ITV4 48020 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT DAVE 24305 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT MORE4 47657 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT BBC4 20684 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT 5USA 52335 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT ITVP1LN 65160 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT PICKTV 48021 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT SKYSHO 16235 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT SSPOME 17744 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT C4P1 56892 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT QUEST 62391 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT YESTDAY 31783 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT 5ST 52336 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT CHALL 21793 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT REALLY 45828 2023-07-14 21:53:34.893 Info LiveTV: Found epg channel in Emby Guide Data GBR-1000118-DEFAULT SKYNEWS 16234 It's entirely possible I've got some dumb misconfiguration at my end but I've tried deleting/re-adding source and guide data and also resetting the HDHomeRun but nothing seems to help. Anyone else come across this before. HDHomeRun shows a total of 168 Freeview channels and they do all play OK in Emby. It just looks like Emby isn't mapping guide data for channels beyond 28. Love Emby btw - you guys are rocking it DH
Luke 42237 Posted July 14, 2023 Posted July 14, 2023 Hi, what channels? Did you try mapping them manually?
dynamohum 4 Posted July 14, 2023 Author Posted July 14, 2023 I think so - for example with channel 29 (ITV2+1) which doesn't show guide data, I set the Guide data source to "Emby Data GBR-100001 18-DEFAULT" but when I click the Guide data channel dropdown list it just shows the first 28 channels so I'm not able to assign it.
dynamohum 4 Posted July 15, 2023 Author Posted July 15, 2023 @Lukequick update on this - I uninstalled/purged the beta version and installed current one and now the listings are all showing so could have been a local issue. I'll see if I can repro with the beta but for now I'll put it down to something dumb at my end.
Luke 42237 Posted July 15, 2023 Posted July 15, 2023 I don't think it has anything to do with the version of the server. It sounds to me like maybe all the guide data had was 28 channels, and you may have picked a different lineup when you set it up again from scratch. 1
dynamohum 4 Posted July 16, 2023 Author Posted July 16, 2023 Yes I'm sure you're right. It's working great now though with the current release so I think I'll leave it as it is and put it down as one thing less to worry about . Thanks for the quick responses. 1
