jashwa 9 Posted December 19, 2023 Posted December 19, 2023 On 12/12/2023 at 10:59 PM, mickle026 said: It needs documenting, but emby server (not this plugin) does not allow you to use certain characters there. As you found out \ and / are two of them, others are " and '. There may be more. It simply doesn't let you use a a double barrelled name out of the box. I think it might be because of sql QUOTED_IDENTIFIER. I have not tested it but you probably have to double them, like \\ and // .. season1//episode1. for it to work. Like I said not tested it. If it screws up you'll have to rescan the item from the movie list view (without opening its detail page), replace its meatadata, to remove the custom id from the db. Sorry about the delay in testing this out. No doubling or escaping works but replacing each / with a \ does! Thanks for your help.
mickle026 653 Posted January 11, 2024 Author Posted January 11, 2024 On 02/01/2024 at 17:33, wangleiqq521.. said: 这些媒体的ID 不是填网页地址马 The IDs of these media are not the result of filling in the web address. No idea what you are asking/saying here .... If the links are not working for you, then you need to either re-read this thread or tell us what you are doing so that we can correct what is wrong for you. The plugin is working just fine.
user24 354 Posted February 18, 2024 Posted February 18, 2024 Hi @mickle026 Very nice work with what you have achieved with this plug-in so far. It took my a little while to figure it out to start off with, but once I did, it is quite easy to configure and use. I have added Official Website and Wikipedia Links for Music Artists. I've only added a few so far, to test out the functionality. As this is working well, I will be adding many more links for other artists bit-by-bit, over time. With Music Artists, I could easily make use of up to 4 custom links (at the moment there are only 2). My use case would be: Official Website | Wikipedia | Facebook | YouTube Sometimes lesser known obscure artists only have a Facebook page from which to find info. Some also have an official YouTube channel. I could imagine that other Music users might also want to add streaming/other site links (e.g. Spotify) so it wouldn't take long to add another half dozen links. Maybe 4 is nowhere near enough!!!! (I would possibly add them as well, but as a lower priority.) Some more examples are: Spotify | Deezer | Amazon Music | Apple Music | Tidal | Qobuz | YouTube Music | Bandcamp | CDBaby I just did a quick test with Spotify and it works correctly. I haven't tried any of the others as yet. This plug-in could end up being very popular with many (across all media categories), once they know about it. Cheers!
mickle026 653 Posted February 18, 2024 Author Posted February 18, 2024 7 hours ago, user24 said: Hi @mickle026 Very nice work with what you have achieved with this plug-in so far. It took my a little while to figure it out to start off with, but once I did, it is quite easy to configure and use. I have added Official Website and Wikipedia Links for Music Artists. I've only added a few so far, to test out the functionality. As this is working well, I will be adding many more links for other artists bit-by-bit, over time. With Music Artists, I could easily make use of up to 4 custom links (at the moment there are only 2). My use case would be: Official Website | Wikipedia | Facebook | YouTube Sometimes lesser known obscure artists only have a Facebook page from which to find info. Some also have an official YouTube channel. I could imagine that other Music users might also want to add streaming/other site links (e.g. Spotify) so it wouldn't take long to add another half dozen links. Maybe 4 is nowhere near enough!!!! (I would possibly add them as well, but as a lower priority.) Some more examples are: Spotify | Deezer | Amazon Music | Apple Music | Tidal | Qobuz | YouTube Music | Bandcamp | CDBaby I just did a quick test with Spotify and it works correctly. I haven't tried any of the others as yet. This plug-in could end up being very popular with many (across all media categories), once they know about it. Cheers! I will revisit this plugin at some point and add more , theres quite a few in your list there, I will see what I can do 1
user24 354 Posted February 18, 2024 Posted February 18, 2024 OK. Thank you. Please consider all those I listed as just possible examples. I would be more than happy with just 2 more general category options. That would give double the flexibility for everyone to add their own Artist favourite links. Up to you of course! In the meantime, I have plenty to keep me very busy with just adding Wikipedia Artist links... will take me a loooong time...
mickle026 653 Posted February 18, 2024 Author Posted February 18, 2024 If you have save nfo enabled, they save there. Then if you ever have to rebuild they will re-import. so you want at least 2 more custom fields that you can make yourself in Artists?
user24 354 Posted February 18, 2024 Posted February 18, 2024 Yes please, that is correct. At least 2 more custom fields. That would give me plenty of scope and possibly be less work for you? If you wanted to implement any of my specific examples as additional fixed fields, at some later stage, that would just be a bonus. Thanks for the nfo tip.
mickle026 653 Posted February 18, 2024 Author Posted February 18, 2024 (edited) A few for you for now, i'll look at more later. (I have not really tested them to see if they work, but they should - we will see ...) See first post for the dll Added Edited February 18, 2024 by mickle026
user24 354 Posted February 19, 2024 Posted February 19, 2024 (edited) Thanks. Most appreciated. I'm happy to help test and report back. I'll split it into parts rather than one really long post. Part 1: (I suspect a lot of what I am finding is possibly more due to URL differences and some site membership restrictions, rather than your plug-in.) I picked two world-famous Artists and two lesser-known Artists to try out the new provided options Eric Clapton | Fleetwood Mac | 8 Ball Aitken | Ray Fuller & The Blues Rockers Artist Facebook EC – tested ok https://www.facebook.com/ericclapton FM – tested ok https://www.facebook.com/FleetwoodMac 8B – tested ok https://www.facebook.com/8ballaitkenmusic RF – didn’t work. I am not on Facebook though, so I ended up getting through to a Facebook log in page. I can get to the required page via Google https://www.facebook.com/p/Ray-Fuller-and-the-Bluesrockers-100063697862309/ Artist Instagram Initially worked with 8 Ball Aitken. Then stopped working through Emby and via Google too. (I am not on Instagram though). Then, wouldn't work for any of the other artists either through Emby or Google. Needs further investigation from me? But I need to do some sort of browser clear/reset first? Artist Reddit EC – tested ok https://www.reddit.com/r/ericclapton/ FM – tested ok https://www.reddit.com/r/FleetwoodMac/ 8B – no Reddit page RF – no Reddit page Artist YouTube (https://YouTube.com/channel/{0}/) EC – tested ok https://www.youtube.com/channel/UCtCOFqqGGGunX71nfZgPQOQ FM – tested ok https://www.youtube.com/channel/UCAb60rVrvVQVfSgrX1UWb0g 8B – reverts to youtube.com because of URL path: https://www.youtube.com/8ballaitken RF – reverts to youtube.com because of URL path: https://www.youtube.com/@RayFullerandtheBluesrockers Custom Artist Youtube Test (https://YouTube.com/{0}) EC – get “This page isn’t available” message FW – get “This page isn’t available” message 8A – tested ok RF – tested ok YouTube observation: Unless subscribed to the channel, YouTube autoplays a video. This limits the usefulness of having this link in Emby for music (e.g. difficult to play music while linking to YouTube). Otherwise, perhaps possible to disable the Autoplay by some other method??? More to follow... Edited February 19, 2024 by user24 incorrect sub-heading
user24 354 Posted February 19, 2024 Posted February 19, 2024 (edited) Part 2: It is interesting that you put Spotify in the Album section. I am not sure how I would use Emby/Spotify this way, but you might have a specific use case in mind? I was thinking of having Spotify (and other streaming sites) in the Artist section. E.g. you are listening to music via Emby and want to see if there is any new music out by a particular artist – it’s then easy to link to the Artist on Spotify (or elsewhere) to find out and perhaps stream, if you are signed up? If I already have the Album on Emby, then I would just play it via Emby. Anyway, I have still tested out the option: Album Spotify EC – The Definitive 24 Nights - tested ok https://open.spotify.com/album/7uLDovmFB97bee1kDTtCNl FM – Rumours (Live) - tested ok https://open.spotify.com/album/24kD7cQnCojzadtNNlplxj 8B – Ice Cream Man 2 - tested ok https://open.spotify.com/album/2NkPbxjONryZEMxEdwzT4h RF – Pay The Price - tested ok https://open.spotify.com/album/59ipkv9JZvC6n8AkuXXWmc So all good with this section as far as I can tell. More testing to follow... P. S. I would still make use of the Custom links in Albums (e.g. for Wikipedia) to be able to read about an album while I am listening to it. Edited February 19, 2024 by user24 Added P. S. section
user24 354 Posted February 19, 2024 Posted February 19, 2024 (edited) Part 3: Turned on custom 3 and 4, I couldn't get the new Album custom sections to work properly, so did a bit of trouble shooting: Disabled all the sections under Album and just selected Custom 1 and Custom 2. These worked as they did previously. Then enabled Custom 3 and was presented with the following error when trying to select any Artist from the Album Artists page: Disabled 3 and Enabled 4. Now 1, 2, 4 all working as expected. Disabled 1, 2, ,4. Enabled 3 only. The above pictured error returns. Highly suspect a typo somewhere in the Custom Artist 3 code. I was going to open the dll file and look for you, but I don't really know what to look for. You will likely find it fast? That's all for now! Edited February 19, 2024 by user24
mickle026 653 Posted February 19, 2024 Author Posted February 19, 2024 Spotify - I have never used it and don't really know their layout. I thought it was albums and track but it seems more like user playlists. Although their site points at albums so I put it there https://open.spotify.com/album/71O60S5gIJSIAhdnrDIh3N OK, so in conclusion Artist - I need to look at custom artist link 3, Artist - Would it be beneficial to you to have a plain youtube link to youtube.com/{0} as well, then you could use whichever fitted your requirement?
mickle026 653 Posted February 19, 2024 Author Posted February 19, 2024 (edited) Uploaded with custom id 3 fix typo for artists + youtube & amazon ids For deezer, i just get "coming Soon" - not available in your country even with vpn located in france from their website so I cannot check the urls they use. Edited February 19, 2024 by mickle026
user24 354 Posted February 19, 2024 Posted February 19, 2024 9 hours ago, mickle026 said: Artist - I need to look at custom artist link 3, Artist - Would it be beneficial to you to have a plain youtube link to youtube.com/{0} as well, then you could use whichever fitted your requirement? Yes and yes. I see you have done it now anyway. I'll update you on further thoughts and further testing a bit later on when I get some free time...
user24 354 Posted February 20, 2024 Posted February 20, 2024 OK, testing continues... Part 4: Custom Artist Link 3 is working correctly. The only additional minor bug that I have found with the Custom Artist Links is that Link 1 does not obey the alphabetical sort order of all the Links on both the Edit Metadata pages and the Album Artist pages. E.g.: Both YouTube options work nicely - thank you! I picked another 6 Artists at random. 3 used the channel URL path and 3 used an @artistname URL path eg: https://www.youtube.com/channel/UCAb60rVrvVQVfSgrX1UWb0g https://www.youtube.com/@fleetwoodmac As per the above examples, some artists use both. I figured out that it is easy to stop the autoplay of the videos by installing a Chrome Extension: AutoplayStopper. There is also an extension just for YouTube, but I like this one better as it blocks autoplay videos on all sites. More to follow...
user24 354 Posted February 20, 2024 Posted February 20, 2024 (edited) Part 5: I asked the Spotify question previously, just because I like finding out about how others arrange their music, that’s all. By going through many of the forum music topics, I have learnt a lot about how to use and customise Emby. By combining people’s tips, a couple of nice plug-ins and some custom CSS, it is possible to create a set-up that works well for me. I’ve also been posting some of what I have learnt, so that others can use the same ideas for themselves if they want to. I tried the Amazon Music link and it takes me to a login page, rather than direct to the Artist page. I expect that this same result could be a potential issue with some of the other streaming sites??? Haven't had time yet to try them all through the custom links... Here is what you need for Spotify Artist: https://open.spotify.com/artist/1LLlMQFnYUd7M9H7dYLR78 Here is what you need for Deezer Artist: https://www.deezer.com/en/artist/4548066 Beyond that, I'm not sure that there is a great benefit in putting extensive time and effort into all of the others (unless you want to). I am most satisfied with: Official Website | Wikipedia | Facebook | YouTube for extensive use Plus a couple of bonus custom links and streaming sites to play around with further. Cheers! P.S. I would cross CDBaby off the list anyway. It's a useful music site, but I an not sure it will work well linking through Emby? Edited February 20, 2024 by user24 Added P.S. Section
rbjtech 5345 Posted November 16, 2024 Posted November 16, 2024 (edited) @mickle026 Hi - it it possible to add an External ID to a Collection type ? I think it should be, as currently it has the TMdbId available as an External ID. I would like to add a custom MDBList url as an external link - which when takes me to the mdblist.com full list. Thanks for your work on this - it's becoming increasingly useful to add External ID's as Emby becomes more integrated with other systems .. edit - so I guess the type is called BoxSet from the API request below on the Id. { "Items": [ { "Name": "IMDB Top 250", "ServerId": "5f9c466f4ecc4319b1d48f55e311d249", "Id": "5425022", "ProviderIds": { "Tmdb": "TEST" }, "IsFolder": true, "Type": "BoxSet", "ImageTags": { "Primary": "a88a12b55a959ca837927aa84dda48db" }, "BackdropImageTags": [] } ], "TotalRecordCount": 1 } Edited November 16, 2024 by rbjtech
mickle026 653 Posted November 16, 2024 Author Posted November 16, 2024 I will add it soon, I have a few days off work coming up, it's not difficult. 1
rbjtech 5345 Posted November 16, 2024 Posted November 16, 2024 12 minutes ago, mickle026 said: I will add it soon, I have a few days off work coming up, it's not difficult. Thanks ! I've been playing with the API for ExternalIdInfo - i can read it, but nothing to push a new one - so the API command in c# or whatever the plugin you use would also be useful
mickle026 653 Posted November 17, 2024 Author Posted November 17, 2024 (edited) Here you go Read this thread, it shows you how I implimented it. Provider_Ids_Extender(17-11-2024).zip Edited November 17, 2024 by mickle026 1
rbjtech 5345 Posted November 17, 2024 Posted November 17, 2024 (edited) 11 hours ago, mickle026 said: Here you go Read this thread, it shows you how I implimented it. Provider_Ids_Extender(17-11-2024).zip 519.59 kB · 0 downloads Amazing - thanks ! I'll try it out a bit later and read up on the thread. update A few issue that I'm looking into There may be some misunderstanding between collections and lists. I believe you are using the actual id rather than the URL for the set item, which is fine but I wanted this to use list= not 'collection=' https://mdblist.com/?list=3090 but getting the list id is a pita, so it's probably earlier to use the url list name https://mdblist.com/lists/garycrawfordgc/disney-shows I'm gonna look at a custom one later on - don't have time atm Gonna use - https://mdblist.com/lists/{0} and then put garycrawfordgc/disney-shows in the emby field hopefully that will work as the direct URL does .. I'll report back later on .. update 2 I'm with you now - mdblist also does collections .. (same as tmdb) .. and those are used for set movie collections (not personal lists) - gotcha ! I'll have a play with the custom 'collection' to provide a solution for the 'lists' .. Edited November 17, 2024 by rbjtech update
mickle026 653 Posted November 17, 2024 Author Posted November 17, 2024 Did you need something else adding in order to do lists?, or can you do that with the custom field? I can add as more custom fields if you need them. I know the slash "/" in "garycrawfordgc/disney-shows" can cause problems in emby and the ExternalID does not support {0}/{1} So to do that you would have to create a custom id with https://mdblist.com/lists/garycrawfordgc/{0}, which would fit all these lists https://mdblist.com/lists/garycrawfordgc/ by using the list name {0} = "Latest TV Shows", ie the id in the metadata field. 1
rbjtech 5345 Posted November 18, 2024 Posted November 18, 2024 15 hours ago, mickle026 said: Did you need something else adding in order to do lists?, or can you do that with the custom field? I can add as more custom fields if you need them. I know the slash "/" in "garycrawfordgc/disney-shows" can cause problems in emby and the ExternalID does not support {0}/{1} So to do that you would have to create a custom id with https://mdblist.com/lists/garycrawfordgc/{0}, which would fit all these lists https://mdblist.com/lists/garycrawfordgc/ by using the list name {0} = "Latest TV Shows", ie the id in the metadata field. Thanks - gonna have a play today - yea it didn't like the slash as you say - I may need to use the list 'id' (numeric) as each list may have a different author - thus embedding the author into the custom id is not gonna be feasible.
Guest Jaqo3000 Posted November 24, 2024 Posted November 24, 2024 Hi, I have installed this plugin into emby plugins folder and i enabled the youtube option but I don't know where can i see the links page in order to put a youtube channel link there? so where should i look after enabling the option "Toggle whether these Provider Ids are enabled in the UI" for youtube?
